Ok got a couple questions for you people. My '85 montes' blinkers, all of the sudden, just stopped working. I'm thinking its not a bulb burned out because the blinkers do not just come on and not blink as if there were a bulb out, it does NOTHING when i hit the blinker. So first of all, I am thinking possibly a fuse but I cant find the fuse box in this car
Then if thats not it, im thinking the actual blinker box but again, have no idea where it is. Any info would be greatly appreciated.
I fix people, not cars.... |
Re: my '85 can't blink!!
You're porbably right on with either a fuse or or the falsher unit itself, especially if the hazards work.
ok all the fuses are good...anyone think its something with the swich in the column?
Yeah, id definately be going for the switch on the column.
Do the turn direction indicators on the dash light up, but no flash? If so, it's the flasher unit. If it's the column switch, the indicators will not light.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1! 2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness! 1967 El Camino L79/M20 old school asphalt raper Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have. |
Try to exercise the hazard flasher switch on and off several dozen times to seat/clean the contacts. Don't operate it like a wild animal, just turn the hazards on and off normally for about 25-50 cycles. If the NC contacts of the hazard switch don't close properly, you'll have no turn signal action whatsoever.
Alright thanks Blue, its sure worth a shot. It sounds like that might work, cause like you say right now there is nothing happening when i hit the blinker but the hazards work fine. I will do that a little later and let you all know what happens.
So whatever happened looking into the contacts anyways?
