Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 10-25-2006, 11:42 PM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
14b oil drain
The 420a is about to be boosted....Just a few more things I have to work out. One problem I have been thinking about is that the oil drain is not going to be facing straight down, it will be more sideways will a little angle down. I'm sorry if this isin't very clear but my question is...Does the oil drain have to be pointed down or the turbo will get f**ked? Thanks
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 10-25-2006, 11:59 PM
Thor06's Avatar
Thor06 Thor06 is offline
Jizzed In My Pants
Re: 14b oil drain
Dont forget to use the subforums...
Build on hold until I get a good paying job, either in school or once I get out. At that time a full tear down and complete rebuild should be in order.
The Purple People Eater will ride again... January 2011 can't come soon enough.
Old 10-26-2006, 12:34 AM
Holset powered 420a
Re: 14b oil drain
Sorry Thor - Didn't really think it belonged under performance, but I guess it does since its about a turbo.
98 Eclipse GS Turbo
2001 BMW 325i - DD
Old 10-26-2006, 12:43 AM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
Re: 14b oil drain
I guess it depends at how much of an angle it will be at because if it's located "too" high up then all the oil won't drain out.
95 Talon TSI AWD
97 Eclipse GST
Old 10-26-2006, 03:50 PM
Holset powered 420a
Re: 14b oil drain
Yea it would be at a pretty steep angle, this is basicle how it would be. Turn the turbo 90degrees to where the oil drain is facing the radiator, then back it up about 1/16 of a turn. I guess im just going to clock both sides of the turbo so that the oil drain faces down.
98 Eclipse GS Turbo
2001 BMW 325i - DD
