Old 10-25-2006, 10:04 PM
linksdeity linksdeity is offline
Quick question about some adapters
Hi, ive got a light im putting in the back of my van, and was wondering what these adapters are for, they came with the package, but it failed to give them a purpose.
Thnx
Old 10-25-2006, 10:31 PM
TheSilentChamber's Avatar
TheSilentChamber TheSilentChamber is offline
Forunn Daberator
Re: Quick question about some adapters
Those are for splicing into existing wires.
Old 10-25-2006, 10:36 PM
Ah, cool thanks.
I suppose my next question is where to splice to get a 12volt current in an 86 Astrovan, but ill get some help from a buddy of mine.
Thnx for the info though
Old 10-25-2006, 10:58 PM
UncleBob UncleBob is offline
AF -Advisor
ahhhh! Scotch locks! Satans spawn!
If you want to run the lights when the key is off, then find a hot-all-the-time power source. If you want to run them only when the key is on, then find a hot-when-the-key-is-on power source....or if you only want them to run when a particular circuit is hot, such as the brake lights or running lights.....well, you get the idea.
Being an 86 astro, there will be provisions for these circuits right in your fuse box, and you can leave the.....a..... *twitch* scotch locks out of the system.
life begins at 10psi of boost
Three turbo'd motorcycles and counting.
Old 10-26-2006, 06:20 PM
psychopathicdude's Avatar
psychopathicdude psychopathicdude is offline
who's buying the scotch?? mmmm.....scotch.
This Space Intentionally Left Blank
