Old 10-25-2006, 08:55 PM
wiringguy wiringguy is offline
94 Astro Van Heater blower not working
Heater blower not working but if i connect direct to the battery it works. When i meter the connection i have power and it reduces as you adjust the switch inside but won't make the blower work.Do you think the relay pack is the problem sucking all the amperage.When i went to a parts supplier they showed 2 different relay packs on their list.
Last edited by wiringguy; 10-25-2006 at 09:20 PM. Reason: insufficent info in title
Old 10-26-2006, 06:18 AM
xt477 xt477 is offline
Re: Heater blower not working
Look just above the blower and check the relay, I found the connector melted on my ole battle wagon.
Old 10-26-2006, 07:43 AM
Blue Bowtie's Avatar
Registered Offender
I've encountered a similar problem on other vehicles. If there is voltage present untill the blower motor is conneted, there is likely a marginal connection i the circuit somewhere. I've found this at the crimped connections on the blower resistor in a few instances, but any other connection or the relay contacts can cause the same symptoms, such as xt477 indicated.
