No start
The car had been running fine and then it would not start. When I got it to start it turned over normally. Now there is no noise when I turn it over. I have replaced the cap and rotor. I am wondering if there is a charging problem. I can compression start it though. If anyone has any ideas can you help me out. Thanks.
Re: No start
If your engine is turning over then make sure you have the correct firing order...if you switched a wire it will keep turning but won't start... It could really be alot of things...try and narrow it down some and it will make it easier to tell what it is! Hope this helps!
-Jimmy- 04' Honda Civic DX 90' Honda Civic DX |
Re: No start
Does your lights come on and everything? If your battery is charged good, and all it does is click: #1: check all connections and make sure they are good. #2: If it still only clicks, try checking your starter relay, its located under the dash above the hood release I believe.
Tony 91 Civic Sedan DX - Stock 287k Miles |
Re: No start
So you pop started it?
If so, then that means it's nothing ignition related. Make sure you check all of your grounds (valve cover, transmission, and thermostat). Make sure the fat white wire on the alternator is tight. Make sure you test your battery not only for voltage, but for current too (amps). You can have a battery w/ 12+ volts and still not have enough current to turn the car over. Most people don't even think about that.
Re: No start
additional question...
what does the valve cover ground do? i cant see any connections that it could be grounding |
Re: No start
89 crx SI - spoiler, custom viper blue paint job, Z6 just completed, stock 14's with a 3 inch drop, sidemarkers, and the stereo "my crx is like my woman: don't like anyone touching her, or driving her but me!"
