1992 LeSabre Trouble Code 13 & 44
I captured trouble codes 13 (O2 Sensor) & 44 (Lean Exhaust).
Q: Is code 44 due to code 13? Q: Is code 13 being caused by something else that's not logging a code? |
Re: 1992 LeSabre Trouble Code 13 & 44
I was kinda hoping for something more definitive in order to avoid replacing parts without knowing if it will correct the problem.
A bad 02 sensor, or vacuum leak, may be at fault here.
If the O2 sensor circuit shorts out, or goes out of range, it may set a fault code. Since you do have a code, the sensor is basically, non-functional. In addition, if you monitor a good 02 sensor on a scanner, you could observe a rapid flip-flop between rich/lean.(5 to 7 times per second) If it does not flip-flop back & forth quickly enough, this would indicate a
Knowledge can be communicated, but not wisdom! ![]() ![]() |
I never had good luck removing something that's been rusted in place for 14 yrs.
How do you get the O2 sensor removed without tearing a hole in the exhaust pipe and/or breaking it off in the exhaust? |
