Closed Thread Show Printable Version Show Printable Version | Subscription Subscribe to this Thread
Old 10-25-2006, 02:59 PM
bille12 bille12 is offline
park avenue interior lights
interior lights come on for a few seconds and go off by themselves. occurs frequently enough to run battery down
Old 10-25-2006, 04:03 PM
Loekee75's Avatar
Loekee75 Loekee75 is offline
Send a message via Yahoo to Loekee75
Re: park avenue interior lights
Welcome to the forums! What year is your vehicle?
http://www.cardomain.com/ride/2653398
1992 Buick Park Avenue (Daily driver)
2001 Saturn SL1 (gas saver)
Old 10-25-2006, 08:46 PM
mschroer mschroer is offline
I had the same problem then it went away and then I had a problem with the interior lights not going off while driving. A real nightime driving hazard. Thought I traced the problem to a bad body control module (BCM). Found a replacement on the web but that didn't fix the problem. Finally found a half decent wiring diagram from ALLDATA and tracked the problem to an input to the BCM. The C4 input terminal to the BCM (grn w black wire) is the auxilary lighting input and comes from the LH and RH front door handles and a Remote Function Actuator (RFA) module. I can't find any information on an RFA anywhere. Pulled this pin from the connector and the lights now go off just fine. The lights don't come on when the handle button is pushed but do when the door is opened. They don't come on when the key FOB is used either. But I can live with this. As near as I can find out the RFA module may be the keyless entry receiver. Known to have bad solder joints. Maybe on the rear deck near speaker.
Old 10-25-2006, 09:29 PM
attn: mschroer
many thanks for the info we will check this out and let you know if
we have any luck. again, many thanks
Old 10-25-2006, 11:03 PM
Alibi's Avatar
Alibi Alibi is offline
Send a message via Yahoo to Alibi
You could just have a short in the interior cabin light switch.
-Eric
89 LeSabre T-Type: CAI, STB, F41 Suspension, Moog Ball joints and tie rods, dual-out flowmaster and dual tips, Pointiac CD HU, Delco type 2 Ignition, etc.
Basic H/C body info:http://www.3800power.bravehost.com/index.htm
http://www.cardomain.com/ride/2318168
Old 11-01-2006, 05:23 PM
gumped gumped is offline
Excuse my ignorance here. I went to the library and got the Buick Electrical Systems Manual for 91 PA and PA Ultra. And I can't find any BCM listed. I found EBCM (Electronic Brake Control Module). But I don't think that is what you are speaking of.
Could you please tell me where the BCM is located in the car? Thanks.
Old 11-15-2006, 11:42 PM
MWW MWW is offline
Not sure if it is much help, but on the '92 PA the BCM is a blower control module. It controls the speed of the heater fan and is located under the hood near the fan and A/C exchanger.
Old 11-16-2006, 01:00 AM
Loekee75's Avatar
mschroer was more than likely refering to a "Body Control Module"....earlier models have "RAC" or Retained Accessory Control modules...basically the same components, just different names.
Closed Thread
