Go Back   Automotive Forums Car Chat > Chrysler > Concorde
Old 10-24-2006, 08:29 PM
twistedtech twistedtech is offline
Code 43,instant limp,sometimes
Been a tech for 23 yrs.Sometimes instant limp code 43( and new today)code 66 no etax ccd recieved.Lose the inst cluster,all of it,and insatnt codes.Scanned with snapon 2500.Trust me,done all the simple stuff,all sensor redings good,new range sensor,new solinoid pac,some new wiring,tsb on tie rod interfere done.1 in 10 times.Insatant 43,reset all,good for a while then off it goes.Wiring done and checked for ohms & loaded 12 volt.All pass.You tell me.
If it ain't broke.......screw with it till it is.
Even at a Mensa convention,
Someone's the dumbest person in the room.
Old 10-25-2006, 02:08 PM
borninabarn borninabarn is offline
Re: Code 43,instant limp,sometimes
If you fix it post it!I have a 95 3.5 i picked up nice car but stuck in limp mode i guess.Start the car about 30 seconds later all the lights on the shift indicator light up only can drive it 30-35mph.Replaced the input and output speed sensors,tryed another tcm checked the wiring harness.Have a known good valve body/solinoid pak in the trunk havent put that in yet.Have read so much about these things doing this kind of gave up for awhile.I was told about a nuetral saftey switch that causes this also i bought a new one that will be put in with the valve body.I guess you have to make sure you use the mopar trans fluid.keep posting on how you do or what you find i will do the same.
Old 10-28-2006, 05:57 AM
After beating my head against the wall way to many times,I told the customer that when it does it again to head off to the Chrysler dealer for a diag only with the drb box and we will go from there.The could not communicate wit hthe car.Good sign,i'll bet that it's either the wiring in the left front wheel well or a bad ccd bus line.Find out next week.
Old 10-29-2006, 11:58 AM
Lets hope they can figure it out!I heard the drbs chryslers uses can idenify problems and trace them better.I will wait to hear from you!!Probley something simple like one wire in the loom have had that before usally under the washer tank like in the caviliers and sunfires.lets hope!Born in Iowa
Old 11-03-2006, 02:54 PM
Re: Code 43,instant limp,sometimes twisted tech any news?
FIXED YET ?????????????????????????????????????????????????? ????????
Old 11-10-2006, 06:29 PM
So it was asked,Fixed yet?.Yes it is.This car had a few minor issues that led up to it's dimise.The ing switch was tired.I tore apart thr column and played with the switch,you could get some wierd azz crap going on by doing that.So anyways,New ing switch( not sure if in my mind yet I am sure it was one of the probs, but it was a prob here.Sometimes no dash at all or only half,and with no shift ind, bcm & tcm cant talk).Removed the 2 plugs at the rf strut tower/firewall and hard wired them.No matter how hard I made the connection by collapsing the female connection it never really connected.Car works golden,for now....................
Old 12-22-2006, 06:05 PM
Just to tidy up this this thread,Car is Golden.New ing switch, tore out the plugs at the RF strut tower and hard wired them,been well over a month now and customer is more thatn happy.Case closed!@ least on this car from h3ll.
Old 07-09-2009, 10:58 AM
Warm_Paw Warm_Paw is offline
What exactly do you mean by hardwiring plugs at RF shock tower?
Did you hard wire two connections from computer?
The majority of posts concerning a dodge 3.3 engine and wiring are basically the same thing. Auto Shutdown relay shuts off fuel and spark. Everyone blames crank or cam sensor but the codes generated just indicate cam and crank not sending signals.
Or tranny in limp mode, which occurs for most faults. Isn't the transmission.
I'm coming up with fact there is a common ground blue black wire for all of these sensors.
Can't find the open or short in actual wire.
I haven't touched ignition yet but can see how it could affect wiring to sensors if ignition not sending hot power to computer or sensors.
I'm tempted to hard wire black blue wire past all sensors to give computer impression all sensors properly grounded. Just not sure if blue black wire sends fluctuating signal?
Don't think it does because it's wire in series to sensors and each sensor would add fluctuating voltage which would garble the signal. Must give a common voltage that computer must recognize and give the OK to energize Auto Shutdown relay.
Therefore hardwiring common wire giving that voltage would give computer big thumbs up.
Whoever thought up wiring by ganging devices and sensors on same circuits must be a dope smoker.
Probably kind of guy who can't find butt with both hands.
The power door locks are keeping time with the flashing dome light while the radio works intermittently and the tach surges up and down like it's possessed. Then horns decide to stay on in rush hour at stop light. Or at 3 am on Sunday night. The Dodge design team must have had a giggle with this brain child.
My mechanic's advice?
Fire Insurance!
