flashing high beam indicator (98)
I have 98 Achieva that had burnt out both of the headlamps. I replaced them and now whenever you start up the car, the headlights flash on and off (as well as the high beam indicator) and continue to do so until I turn on the headlites manually. Any suggestions?
Re: flashing high beam indicator (98)
our 98 almost always had blinking indicator in the dash with the car running, except for a couple or few days
coudl not figure out why and when the IPC gets back to here form southern after its repair i will see if it still does that or not i thought ours was the only one doing that interesting god luck
I also am user fastr68 here- Randy -'54 F100 302 C-6 -'57 F100 -'57 Bel Air HT 307 4spd '57 210 HT 4dr 265 3spd -'68 corvair monza convertible w/ PG -'79 C-20 -'80 K-20 -'82 K-10 SS -'82 TRANS AM WS7 HT 5.0L TH350 2400 stall blue/blue level III PMD cloth PG hood -'85 Elky SS 310ci 2004r fully restored 2008 -'88 buick century estate wagon 3800 4t40e, 91 s-10 2wd 4.3L, 96 taurus, '97 cavalier RS 2.2L, 5sd -'05 18ft car trailer, 98 achieva, 98 cherokee, |
Thanks Randy78. Can't wait to hear from you!
Mick |
got the IPC back from southern after they rebuilt it and the indicator never has come on, neither have any other lights, all is well the car runs and drives like a brand new one the car is fixed yay
good luck
I think I found my problem. I recently installed new bulbs in both headlites. Just realized the high beam did not work on the left. Checked it out and when I initially installed that bulb I compressed the part between the bulb and the mounting part. Replaced the bulb and it works just fine now.
youre lucky then
![]() congrats :P
