Go Back   Automotive Forums Car Chat > Ford > Ranger | Courier
Old 10-24-2006, 06:17 PM
KDRichards KDRichards is offline
AC Compressor Clutch cycles
On the way home from work I turned on my heater and soon began to hear a clicking sound. I looked under thge hood and my AC compressor clutch was cycling on and off every 30-40 seconds. I turned off the heater and drove home without hearing the sound. Is my compressor clutch going out or could it be something else? Also, if need be can just the clutch be replaced or will the compressor need to be replaced? Thanks for any input.
K. D. Richards
Old 10-24-2006, 07:35 PM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: AC Compressor Clutch cycles
K. D. Richards
Welcome on your first post on AF.
Does it do the same thing with ac on?
If so it is usually low freon or a bad pressure switch on ac.
MT
MT
Old 10-25-2006, 11:28 PM
Marbles1984 Marbles1984 is offline
It does that to keep your compressor from locking up in the winter. Don't worry, its normal. Mine does it when I turn the defrost on. If it cycles when you have the ac on though its low on freon. The compressor should stay on when the a/c freon level is ok.
Old 10-26-2006, 09:30 AM
MT-2500's Avatar
AF - Advisor
The AC is used on defrost cycle to help keep the moisture off of windshield and window glasses.
Fast cycle on and off is a sign of a problem.
If it keeps doing it fix it or unplug it.
MT
MT
