Go Back   Automotive Forums Car Chat > Chevrolet > Impala | Impala SS
Old 10-24-2006, 04:30 PM
micali micali is offline
2000 LS stutter
I am looking at buying this 2000 LS from a used lot but the car has a minor issue. At around 58-62 mph, if the car is under a load, it stutters then it takes off. What could cause this? They replaced the Throttle positioning sensor and that didn't help. I can buy it for $5,500 the way it is. It has 94,000 mi and has only had 2 owners and the second was a lady.
Old 10-24-2006, 05:01 PM
Re: 2000 LS stutter
They said that if you start to accelerate within that range is stutters but then you can punch it and it takes off. Anything before that or after that there isn't a problem.
Old 10-24-2006, 06:44 PM
Re: 2000 LS stutter
It does it between 30-40mph, it hesitates then does ok. IT doesn't do it all the time.
Old 10-24-2006, 08:00 PM
2000 LS Tranny Failure?
If anyone has had to have the tranny replaced can you please tell me what were the problems you had before and that lead up to the tranny replacement. Thanks!
Old 10-24-2006, 09:22 PM
car jerks during accleration, Please help
I have a 00 LS with 94,000 mi on it. I've noticed that the car jerks during accleration at or around 40-60mph. It doesn't shift hard at all just hesitates within those ranges. It doesn't do it all the time, there isn't anything I can do to make it do this, it just does it when ever. Could the PCS cause this? TPS and Fuel pressure regulator has been changed. Please any help at all would be great!
Old 10-24-2006, 11:02 PM
ehines91 ehines91 is offline
Re: car jerks during accleration, Please help
I have a 2003 Impala with 113,000 miles on it and I notice the same problem between 10-20mph. Maybe we have the same problem. Just thought I'd let you know that you're not alone!
Old 10-25-2006, 08:24 AM
It only acts up after the car has shifted thru all the gears and you begin to accelerate. It begins to hesitate as you accelerate, the tac jumps back and forth. It does it pretty consistantly. If you hard accelerate you don't notice it at all.
Old 10-25-2006, 02:53 PM
maxwedge maxwedge is offline
A990 racer
Sounds like an ign misfire under load to me, or the tcc is shuddering any codes?
Old 10-25-2006, 09:29 PM
Re: 2000 LS stutter
I decided to not buy the car. Thanks anyway.
