Go Back   Automotive Forums Car Chat > Nissan > Sentra | 200SX (USDM FWD)
Old 10-24-2006, 03:56 PM
ProZach626's Avatar
ProZach626 ProZach626 is offline
Send a message via AIM to ProZach626
Education.. suspension
What is the difference between shocks and coil overs?
Old 10-26-2006, 12:54 AM
Chiquae07's Avatar
Chiquae07 Chiquae07 is offline
Send a message via AIM to Chiquae07 Send a message via MSN to Chiquae07
Re: Education.. suspension
search google or how stuff works, im too lazy to do another google search, as im going to sleep.
2008 Mazda 6 ATX 2.3 Liters of Slowness
For those 9 seconds it takes me to reach 60mph, will be the most fun ill have in this car.
Old 10-26-2006, 06:58 AM
sincspecv sincspecv is offline
basically, coilovers will be struts with the springs on them. coilovers will be set up so you can adjust the height of the vehicle by moving the seat of the spring. fyi a B15 has struts not shocks.
Old 10-26-2006, 07:01 AM
also, if you're buying coilovers, make sure you actually get coilovers, not sleeve overs. They're kinda the same thing but a sleeve over retains the strut that's already on the car. not to mention they only hurt perfomormance.
Old 11-12-2006, 12:51 AM
nismo_pilot nismo_pilot is offline
Send a message via AIM to nismo_pilot
coilovers have the damper inside of the spring coil, enabling lower ride heights and increased control, shocks are actually called dampers and just dampen spring movement, a strut on the other hand, integrates the damper and spring in one unit, different from traditional shock and spring suspensions found on older cars where they are no where near each other, better now?
2005 Aztec Red Spec-V
Nismo header, ES MMI, AEM CAI, UR Pulley, TB Coolant bypass, TWM SS, Kumho Ecsta's, 2x JL Audio W0 subs
9.02@ 84.4mph in the 1/8th....... Driver > Car
