Go Back   Automotive Forums Car Chat > Ford > ZX2
Old 10-24-2006, 03:22 PM
karensman_0416 karensman_0416 is offline
Question No heat or air though vents?????
Hello i have a quick question. i just took my cd player out of my zx2 and now the heat and air will only go though the defrost not the vent's or the floor??? I checked all the connection's and they all are connectioned. so i am a little confused on this.any help would be great. thanks
Old 10-24-2006, 09:42 PM
Markb873 Markb873 is offline
Re: No heat or air though vents?????
Those vaccum lines control it. Follow them from end to end, Make sure the connectors aren't loose. Mine has a tendancy to come loose when I try and hook up the temp control, well untill i beat out that small spot welded rail on the bottom. Now I have plenty of room.
Old 10-26-2006, 01:05 AM
hotrod_chevyz's Avatar
hotrod_chevyz hotrod_chevyz is offline
Look inside the hole where the stereo was and see if you bumped anything loose or anything.
Old 12-20-2006, 02:52 PM
jldude jldude is offline
80% probablility. There's a red connector with 4 0r 5 contacts that plugs into the mode selector switch that is still disconnected. I recently did exactly the same thing, pulled my cd player out and I unplugged this connector without even knowing it. The dealer charged me $72 just to plug it back in. it plugs in right under the connector with the 4 big wires into the far right switch.
Old 12-20-2006, 02:56 PM
most likely solution is you unplugged a connector without knowing it. I recently did this as well, and it's a red, 4pin or 5pin connector that plugs into the mode selector switch right under the big one with the 4 colored wires. look around in the hole and see if you can see another red connector loose. that's your most likely cause.
Old 10-11-2007, 05:02 AM
GrZX2000 GrZX2000 is offline
Hey guys,
I'm having the same problem with air/heat only coming through the defrost. After I picked my car up from the shop, I found this problem. The guy told me that something else could have been wrong with the car. I always thought it was just something that was loose.
Is this connector inside the car or under the hood? And, if it's in the car, is it under the dash? Which side?
Thanks!!!
GRZX2000
Old 10-11-2007, 07:52 PM
It's the connecter behind the control, it's a cluster of vaccum lines.
