Go Back   Automotive Forums Car Chat > Lincoln > General Discussion
Old 10-24-2006, 02:38 PM
LONGJOHN LONGJOHN is offline
Send a message via AIM to LONGJOHN Send a message via Yahoo to LONGJOHN
Oil in water
Have 91 towncar with oil in radiator reservoir. Anyone know how this most likely to happpen????
Old 10-24-2006, 03:44 PM
JustSayGo JustSayGo is offline
Send a message via AIM to JustSayGo Send a message via Skype™ to JustSayGo
Re: Oil in water
From a broken transmission oil cooler or engine oil cooler that is inside your radiator.
Old 10-24-2006, 04:54 PM
Towncar's Avatar
Towncar Towncar is offline
Re: Oil in water
Or:
Bad head gasket; Cracked Cyl wall; Cracked block; someone poured it in the wrong hole
-Steven
1996 Town Car, Cartier
Old 10-24-2006, 05:11 PM
Re: Oil in water
Because things flow from higher pressure to lower pressure it is extremely unlikely that Or:
will result in oil in the cooling system. Leaks in blocks, heads, or gaskets result in coolant mixing with the oil in the crankcase. Oil pressure in either oil cooler is greater than cooling system pressure while the engine is running. Cooling system pressure is greater after a hot engine is turned off maybe as high as 16lbs psi. If the coolant has enough time to leak a little into the oil at 16lbs, just imagine how much oil at 60psi will leak from the same hole between oil and cooling system during the entire time the engine is running.
Old 10-24-2006, 05:24 PM
Towncar's Avatar
Re: Oil in water
Yeah, all that ^^
But it happens regardless ... you are correct about "most likely".... I overlooked that part of the question.
-Steven
