Old 10-24-2006, 02:15 PM
X2Xtreme360 X2Xtreme360 is offline
no fuse box cover
I'm testing something and I need to know which fuse(s) under the dash only work when either the corner lights or headlights are on. Also, I need to know where they are located because the previous owner sold me the car without the cover. Thanks.
Old 10-24-2006, 05:17 PM
Linebckr49's Avatar
Linebckr49 Linebckr49 is offline
Send a message via AIM to Linebckr49
Re: no fuse box cover
i can't say that i've ever seen a 3S with a cover for the fuses under the dash. but that's not to say they didn't come with one from the factory. i'd check the service manual for fuse diagram.
93 3000GT base
K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2
coming soon: adj. cam gears | bi-xenon HID retrofit
Old 10-24-2006, 05:27 PM
Linebckr49's Avatar
here ya go. service manual FTW!
93 3000GT base
Old 10-24-2006, 11:42 PM
awesome. Thanks!
