Go Back   Automotive Forums Car Chat > Nissan > Sentra | 200SX (USDM FWD)
Old 10-24-2006, 12:02 PM
MiXdNuTs MiXdNuTs is offline
Change fuel filter
I have a 1994 Sentra that I am using to learn car repair. I have done full new breaks, gaskets, sparkplugs/wires, distributor/rotor, PCV valve, ect. already.
I am going to replace the fuel filter now but I read that I need to relieve the pressure on the fuel line before I disconnect the old fuel line. The process has something to do with putting the keys in the ingition, but beyond that I don't know.
Can anyone tell me how to take the pressure out of the fuel line (and then put it back when I am done ) I need to not die in the process so any safety tips are appreciated.
Also, does anyone know if Nissan put this filter under the hood or below the car between the tank and the engine?
Thanks guys! and yes I am a new member.
Old 10-24-2006, 01:29 PM
fugiot's Avatar
fugiot fugiot is offline
Send a message via MSN to fugiot
Re: Change fuel filter
It should be under the hood between the engine and the firewall. And all you have to do is take off your gas cap off before you remove the filter. Don't worry too much about all the pressure stuff.
1.remove gas cap
2.change filter
3.replace gas cap and go
SR20 powered SE-R: 60mph-6.2 sec., 1/4mi.-14.7 sec.
VG30 powered Maxima SE: 60mph-7.8, 1/4mi.-15.8 sec.
Don't make me ANGRY
Or I will kick you in teh NUTS
Your NUTS will feel teh steel toe
Teh steel toe that has been in teh snow
I will rip off yuor pants and kick yuo in teh nuts
My steel toe will stick to yuor nuts
And I will swing yuo around by yuor nuts as I do a Hurricane kick
Old 10-24-2006, 01:52 PM
Sounds good enough to me. Now I just need to find the darn fuel filter. Cars with 170k miles seem to all be the same black color under the hood.
Old 10-25-2006, 02:19 PM
Is there any stratification amoung fuel filters? I mean are there some that are to be avoided or are they all pretty much similar?
Old 10-25-2006, 02:22 PM
fugiot's Avatar
meh, they're all the same. Avoid "performance" filters(yes, I've seen them), you don't want crap coming through your line for the sake of slightly free-er flowing fuel.
Don't make me ANGRY
Old 10-25-2006, 02:32 PM
Thanks for the quick reply. I will go by autozone tonight and get whatever they have.
Also, how often do you change your tank filter?
Old 10-25-2006, 06:05 PM
fugiot's Avatar
Tank filter? Shouldn't ever have to change that unless you score over a quarter million miles on your car.
Don't make me ANGRY
Old 10-26-2006, 07:10 AM
Great help so far. I really appreciate it.
I have been giving my car a tune up and I wanted to make sure that I didn't pass over anything obvious that it needs. It has 170+ miles and no tuneup for at least 30k. I have just given it new plugs, plug wires, distributor cap, rotor, valve cover gasket, pcv valve, and fuel and air filters. I am going to have my alignment done at a car shop.
Anything else that I should do?
Old 10-26-2006, 07:20 AM
sincspecv sincspecv is offline
oil change
Old 10-26-2006, 12:53 PM
fugiot's Avatar
haha
Don't make me ANGRY
Old 10-26-2006, 02:01 PM
Originally Posted by sincspecv
oil change
Ok, you burned me good with that one. I still have 2k miles to go before I need another oil change though.
Old 10-27-2006, 06:28 PM
JerodKing JerodKing is offline
Send a message via AIM to JerodKing
Actually the best way to remove fuel pressure from the lines is to take out the fuel filter fuse (up by battery) and then start your car. Once it stalls crank it a few more times. And maybe it's because I'm just picky, but I only use Nissan fuel filters and would definately use Nissan oil filters. Don't buy Fram, they are shit and have been proven to be so.
Old 10-27-2006, 07:16 PM
slideways...'s Avatar
slideways... slideways... is offline
thats the way i always release fuel pressure. and i use k&n oil filters. but on a 94 sentra that your just using to learn on, dont worry about using fram. itll do fine. that or napa gold filters.
Rice Police #1. dont argue with me just because you are a riceboy and/or have sand in your vagina. i am superior. and i am smarter than you. end of story.
Old 11-12-2006, 12:55 AM
nismo_pilot nismo_pilot is offline
Send a message via AIM to nismo_pilot
perfect, i was about to say that when i read your post
2005 Aztec Red Spec-V
Nismo header, ES MMI, AEM CAI, UR Pulley, TB Coolant bypass, TWM SS, Kumho Ecsta's, 2x JL Audio W0 subs
9.02@ 84.4mph in the 1/8th....... Driver > Car
Old 11-20-2006, 05:39 PM
dreww dreww is offline
Actually the best way to remove fuel pressure from the lines is to take out the fuel filter fuse (up by battery) and then start your car. .
close, its actually you remove the fuel PUMP fuse (upper left corner of fuse box) and run the car til it dies.
I had to actually start the car first (with the fuse in) to get it to start. Then pulled the fuse and restarted until it died (took less than 3 seconds). Pressure relieved.
