Old 10-24-2006, 10:30 AM
JOKER120 JOKER120 is offline
code 42 is asd where do you start
i have 96 caravan 3.8 will not start i get power to coil pack when you turn key over I BELEIVE I DO NOT GET THE 3 GROUND SINGLES AND WHERE IS THE ASD LOCATION i need help thank you
Old 10-24-2006, 01:53 PM
RIP's Avatar
RIP RIP is offline
AF -Advisor
Re: code 42 is asd where do you start
The ASD relay is in the fuse/relay panel next to the battery. Try reseating it. Try tapping on it while cranking.
**We took the time to answer your post. Please give us some time and post the fix. It will help hundreds.
**Follow prescribed safety practices before attempting any procedures. Doubts? Consult a maintenance manual.
07 Fusion / 06 RAV4 / 06 Accord / 96 Gr Caravan
Old 10-24-2006, 02:24 PM
taping on relay did not help thanks
Old 10-24-2006, 05:31 PM
RIP's Avatar
RIP RIP is offline
AF -Advisor
Try this: http://dodgeram.org/tech/gas/Trouble/Fault-42.htm Scroll to "Diagnosis procedure"
Old 10-25-2006, 10:41 PM
i think it is the whole fuse box there is a short on power side to asd relay
so it has power all the time
I THINK THIS IS THE PROBLEM
Old 10-25-2006, 11:40 PM
RIP's Avatar
RIP RIP is offline
AF -Advisor
You should have 12 vdc power at relay socket contacts 86 and 30 all the time. Is this what you are seeing?
Are you getting about 75 ohms resistance across the coil contacts 85 and 86 on the relay?
Are you getting continuity (zero resistance) across relay contacts 30 and 87A?
Should be getting no continuity (infinite resistance) across relay contacts 30 and 87.
Old 11-05-2006, 06:06 PM
papiichuulo papiichuulo is offline
AF Premium User
Was it fixed???
