Go Back   Automotive Forums Car Chat > Chevrolet > General Discussion
Old 10-24-2006, 09:36 AM
jveik jveik is offline
just wondering...
does anyone happen to know or be able to make an educated guess as to how much power i need to do the following....
burn out all the way up to about 80 or 90 miles an hour before the tires finally catch completely
this would be with a 73 c-10 im building that has a 383 waiting to be dropped in, backed by a turbo400 with a transpak and the stock 12 bolt posi rearend that came with the truck. i dont know the ratio of the rearend, but it used to be able to go 60 in first gear with the 350 i had in there before i gutted the truck out. i recon i was doing over 6000 rpm at that point due to the ricer-like whine of the motor
Old 10-24-2006, 10:29 AM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Re: just wondering...
Spinning the tires at 90MPH is not in the best interest of control, stability or safety. You would be instant roadkill.
Besides, it won't happen. Even an 800hp NASCAR Nextel Cup engine can't do that.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 10-25-2006, 08:42 AM
yeah i suppose barking the tires shifting gears at 90 is a little different than actually roasting them all the way up to that speed.
i assume that even if i had the power to do a burnout that long, i would probably have the rear end come out from under me and fishtail into a guardrail or something before i got anywhere near that speed
Old 10-25-2006, 08:47 AM
BLU CIVIC's Avatar
BLU CIVIC BLU CIVIC is offline
調整器
Send a message via MSN to BLU CIVIC Send a message via Yahoo to BLU CIVIC
you could in a bpu+++++++++++++++++++++++++ supra
The name's Adrian
1990 Civic HB Si - 265.7whp/223tq @9.2psi. Tuned on NepTune by J.Mills
1991 Civic Sedan DX - 296.3whp/230tq @1bar. Tuned on NepTune by J.Mills
1991 Civic Sedan DX - 185.8whp/139tq. Tuned on NepTune by J.Mills
2006 G35 Coupe 6MT - Stock
2011 CR-Z - Stock
Old 10-25-2006, 09:58 AM
Blue Bowtie's Avatar
Registered Offender
A few road racers have dropped gears coming out of corners at 70-80 MPH and burned tires well into the straight stretches and well into three-digit speeds. If the car is set up to track straight, and a qualified driver is at the wheel, it doesn't always end in a pile of wrinkled metal.
Old 10-27-2006, 08:38 AM
haha!!! i bet if i got rear tires as skinny as the ones on my honda accord for the truck, it would throw a rod burning out so much
Old 11-03-2006, 02:17 PM
GreyGoose006 GreyGoose006 is offline
yeah, you wont be burning out much past 50 if you put wide enough tires on it to be able to get any traction for launching.
i'd go with WIDE tires and settle for 40-50 mph burnouts.
Old 11-06-2006, 08:24 AM
yeah i think my main objective will be to not do any burnouts if possible on my good tires, then every once in a while i might swap some crappy old rims on there with old tires and have some fun
