Go Back   Automotive Forums Car Chat > Dodge > Intrepid
Old 10-24-2006, 08:48 AM
Firewind's Avatar
Firewind Firewind is offline
Signal light stops working at random
My friend has a 2002 Dodge Intrepid. When he turns his signal on either right, or left it will at random stop working, and has to turn it off, and back on again for it to work again before it stops signaling. Anyone else heard of this happening, or knows what the problem might be?
Thanks
Adam
Old 10-26-2006, 01:34 AM
AWP9521 AWP9521 is offline
Re: Signal light stops working at random
Sounds to me like you might have to get a new multifunction switch since they operate the turn signals, wipers/washers, hazard flashers, and high beams. I had a similar problem with a 94 LHS and found that ig you cycle the hazard switch on and off the signal would work again but that was for one direction only and not both. You can try that but I got a feeling this problem is a little deeper a the switch replacement may be the only cure.
Originally Posted by AWP9521 - 02/16/2005
Sure sex is a thrill too, but your modified car will never tell you
"Sorry honey, I just don't feel like it tonight" it will always be in
the garage silently waiting for you to hop in so it can thrill you
some more, that is unless you break it. At least they're easier
to repair and get the thrill back than a pissed off girlfriend.
