Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 10-23-2006, 05:31 PM
cluelessart cluelessart is offline
Door removal and replace
I have a 95 Ram 1500 and need to change the doors on both sides, It has manual windows so there is no wiring involved. Is it hard to remove and replace a door or should I have a garage do it?
Have a nice day
Cluelessart
Old 10-24-2006, 01:22 PM
HeavyJ HeavyJ is offline
Re: Door removal and replace
Its not hard, just they are a little heavy and not easy to handle, plus body shops have a door lift they use that holds the door in place while tech puts bolts in and adjusts it. if you do it, get a helper, use a floor jack with block of wood under the inside of the door. good idea to use some masking tape around the outer edges while adjusting so if your off you dont nick the paint. be patient and it shouldnt take you long to get them on right.
