Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 10-23-2006, 04:31 PM
Black99GST's Avatar
Black99GST Black99GST is offline
Send a message via AIM to Black99GST
ARP's...
ok, so i picked these up... and the mother f*ckers forgot to give me the directions... anyone have them that they can email to me? the 7-bolt ARP headstuds torque info sheat? i guess its good that they gave me two (2) packs of the molly lube... but still no directions...
(pic from Cell Phone *dont have a digital camera anymore*)
Old 10-23-2006, 06:54 PM
Blackcrow64's Avatar
Blackcrow64 Blackcrow64 is offline
Re: ARP's...
-Index for Tech Articles-
I do believe you can find info on the ARP's and their torque specs here.
I'm so glad we finally have a tech section.
-Brian
  • 92 Firebird sold
  • 97 Talon TSI AWD sold
  • 05 Cobalt LS sold
  • 02 Tahoe LT sold
  • 06 Cadillac STS4 AWD sold
  • 03 Corvette Z06 sold
  • 14 Silverado 1500
  • 26 Equinox RS
Old 10-23-2006, 07:15 PM
Thor06's Avatar
Thor06 Thor06 is offline
Jizzed In My Pants
Re: ARP's...
Search n00b.
JP man...
Build on hold until I get a good paying job, either in school or once I get out. At that time a full tear down and complete rebuild should be in order.
The Purple People Eater will ride again... January 2011 can't come soon enough.
Old 10-23-2006, 07:38 PM
Black99GST's Avatar
Re: ARP's...
no i found that before, read keven's post, looked at ARP's website... but on the site they dont have my kit (207-4203) listed... here look for yourself!
http://www.arp-bolts.com/Tech/TechTorque.html
lol i've been around... just cant find any results...
so someone with 7 bolt arp's can you post up a copy of the instructions that where "included"
Old 10-24-2006, 04:50 PM
Black99GST's Avatar
Re: ARP's...
still need the exact torque specs...
Old 10-24-2006, 09:47 PM
Re: ARP's...
Torque Specs - Complete List
Seriously... lol This is why we made the Tech section.
Also, post 3,000... Yayness!
-Brian
  • 92 Firebird sold
  • 05 Cobalt LS sold
  • 02 Tahoe LT sold
  • 14 Silverado 1500
  • 26 Equinox RS
Old 10-24-2006, 10:40 PM
Black99GST's Avatar
Re: ARP's...
thats OEM, is that the same? because keven was saying around 80 ft/lbs or so...
Old 10-24-2006, 10:53 PM
Re: ARP's...
Hold on you bastard... lol
**EDIT**
I want you to know that my drunk ass stumbled down 3 flights of stairs for this. Then I proceeded to move all my motor internals just so I could get to the paper in the ARP box for you... This is gonna take a while to type it all correctly... Oh, and I'll bolded the important parts for you...
Installation Method for Head stud kits
190,000 PSI 12MM Diameter
1. To ensure proper thread engagement and accurate torque readings, clean and retap ALL threads in the block. Retap only if neccessary.
2. Clean and inspect all hardware prior to installation. Look for obvious defects or shipping damages, plus proper fit, length and dimension.
3. A. If cylinder head studs protrude into water jacket, lubricate the block threads of the studs with ARP Moly Lube or 30wt. motor oil.
B. If cylinder head studs protrude into blind hold, lubricate the threads, nuts and washers with ARP Moly Lube or 30wt. motor oil.
C. Screw studs into the block "HAND TIGHT ONLY"
4. Install cylinder heads and check for binding or misalignment.
5. ARP recommends using the ARP Moly Lube or at the very least, a good quality Moly Lube as opposed to motor oil. This is due to higher friction on the studs as well as inconsistencies in the clamping force of the fastners when motor oil (or low quality lubricant) is used.
PRELOAD TORQUE RECOMMENDATIONS:
Torque values are based on 75% of the fastners yield strength. Use the manufacturers torque sequence but do not use the engine manufacturers torque specs. Torque the nuts to 80 ft. lbs for ARP MOLY Assembly Lubricant (or the ARP Thread Sealer) or torque to 120 ft. lbs with 30wt motor oil.
So there you have it... Straight from ARP themselves... You can send me another 40 cause this one is gone... via UPS... No Fedex... They piss in my driveway... Bastards...
-Brian
  • 92 Firebird sold
  • 05 Cobalt LS sold
  • 02 Tahoe LT sold
  • 14 Silverado 1500
  • 26 Equinox RS
Old 10-25-2006, 03:16 AM
kjewer1 kjewer1 is offline
AF - Advisor
Re: ARP's...
I added a little more detail in a post I made here. It is also on the Tech Pages on my site.
ARPs website lists the torque specs for every stud based on tensile strength and diamter. The DSM studs are 190 psi, 11mm for 7 bolt, 12mm for 6 bolt. Very easy to look it up on thier site.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
