Go Back   Automotive Forums Car Chat > Saturn > SC/SL/SW
Old 10-23-2006, 02:20 PM
JaiWilson JaiWilson is offline
Question Light.. Won't.. Stop.. Blinking..
My engine coolant/auto transaxle fluid light started blinking... Added antifreeze a couple of times, but didn't fix the problem... Car started to overheat... Took into Sear's... They said I had a cracked radiator, and $400 later I was good to go... The light started blinking again before I got out of the parking lot... Any ideas? Does it need to be reset?
1994 Saturn SL2
Old 10-24-2006, 11:20 PM
69goatfarmer's Avatar
69goatfarmer 69goatfarmer is offline
Re: Light.. Won't.. Stop.. Blinking..
My 94 SL2 does this when the fluid in the overflow reservoir gets low. Might be a bad switch if the fluid is OK. Did it really overheat? Since the air dam in the front was broken off by my wife the vehicle does tend to run hot when idling in traffic but it doesn't overheat. Temp gauge creeps up but then falls back down when thermostat opens.
I was told I had a cracked radiator by Saturn about 70,000 miles ago and that I had to replace it right away. Still waiting for the "right away" part.
58 Cushman Scooter
69 GTO Conv 400/4sp
66 GTO Hardtop 428/Auto
75 Honda CB550
04 Grand Prix GTP Comp G
Old 10-25-2006, 10:51 AM
saturnspeed_12's Avatar
saturnspeed_12 saturnspeed_12 is offline
if the overheat and low coolant light are both flashing, that can point to a bad coolant temp sensor and possibly bad connector to it too. if the sensor is cracked, the connector HAS to be replaced. only replace the sensor with a brass tipped one. plastic ones are junk, so dont buy until you look. normal parts stores usually keep the plastic ones, while the dealer has brass ones.
Ian
Saturn Tuners Club-OH Chapter President
1993 Saturn SC2 rebuild project for dad
1995 Saturn SL2 current daily driver /w a lot of work
2007 Chevy Cobalt injen cai, full lsj exhaust, dc sports fsb, progress springs and rear sway bar, enkei wheels/hankook rubber --*boost in progress
