Go Back   Automotive Forums Car Chat > Ford > Ranger | Courier
Old 10-23-2006, 11:46 AM
b16Civic b16Civic is offline
Have an air leak, where to look for it?
found out my check gas cap light came on because theres an air leak, so where do i look for it thanks.its a 2002 4cyl.
Old 10-23-2006, 12:55 PM
12Ounce 12Ounce is offline
Re: Have an air leak, where to look for it?
I'd start at the hose nipple under the throttle body. There is a small diameter hose that hooks up there, goes thru a small valve and flow sensor on to the carbon cannister. From the cannister, another hose picks up and goes to the firewall where it hooks to a metal tube ... and from there back to the fuel tank.
Most likely, the leaks are in the hoses under the hood ... but if not there, you will have to check the hoses on top of the tank.
Old 10-23-2006, 11:32 PM
e_powers e_powers is offline
actually there is a design flaw with the fill tube from the gassnozzle to the tank. they tend to crack with age. i dont know exact process but i have seen a fix that envolves a fuel resistant rubber hose to replace it. or a ford factory replacement. i would start by checking the actual cap first
starting to love my 93 ranger w/3.0 5 speed.
Old 10-24-2006, 03:45 PM
i'll check under the hood, because when its on i can hear a noise like a leak in the engine bay.
Old 10-24-2006, 09:00 PM
ok???
Old 10-27-2006, 04:28 PM
turns out there is an air leak in the bay and i've found it but its a small white plastic hose about 1/4 inch in diameter that goes to another little hose and into the carb housing is that it?
Old 10-27-2006, 04:29 PM
or should i replace the gas cap?
Old 10-27-2006, 06:36 PM
Just continue to find and repair air leaks. When the system is leakproof enough, the light will go out ... that is, after a 100 miles, or so, of driving.
And, yes, the gas cap may be part of the leakage.
