Go Back   Automotive Forums Car Chat > GMC > Sierra
Old 10-23-2006, 02:05 AM
Ripsta7sign Ripsta7sign is offline
89 truck lack of power,hesitation,misfire
The problem has me puzzled when its cold its fine i can accelarate good it idles wonderfull i mean theres nothing wrong.but when it warms up and i accelarate it falls flat in its face it loses all the power completly.and if i floor it to wide open throttle it misfires and flames come out the throtle body.i replaced the fuel pump and filter and no luck.And theres no ses light on either.if any one can help it would be apreciated
Old 10-23-2006, 01:26 PM
2000CAYukon 2000CAYukon is offline
Re: 89 truck lack of power,hesitation,misfire
This sounds like a classic case of a plugged cat or exhaust. Drive it at night and park in a dark spot and see if the cat is glowing red. If so, the cat is clogged and needs to be replaced.
An exhaust back pressure test can also help pinpoint an exhaust restriction.
//2000CAYukon
Old 10-26-2006, 04:24 PM
loganlott loganlott is offline
well man not looking at it i would say fuel injectors are dumping to much fuel. uh oh!
2005 Chevy Z-71 Ext. Cab
2003 Dodge Ram SLT 4x4 Laramie QuadCab
2000 Chevy Camaro SS
Old 10-26-2006, 04:49 PM
A bad engine coolant temp sensor can also cause it to get too much fuel when warm. If it is off far enough, you should get a check engine light. Is the check engine light on?
//2000CAYukon
Old 10-26-2006, 10:01 PM
fuzzypuppy's Avatar
fuzzypuppy fuzzypuppy is offline
If it's flaming through the TB the problem points to timing and possibly ignition components, dist etc.
When the engine is started and run cold the computer advances the timing after warm up it retards the timing, this would account for the drastic change with temp rising.
A clogged cat could cause the loss of power as suggested but not the flame through the TB, and it's very doubtfull a fuel delievery problem since neither flooding or leaning will cause the flame out you described.
I'd start by checking the timing after the engine has reached temp, " when your problem exists" , if the timing looks ok check the timing after you reconnect the est wire and look at your advance when you hit the gas a bit, it sounds like your dist may not be advancing when you hit the gas after warmup.
