Go Back   Automotive Forums Car Chat > Racing > Non Specific
Old 10-22-2006, 11:14 PM
charlymaster charlymaster is offline
chasssi Spring preload
hello everyone.
I have seen some race car that has a rod preloading their spring, and of course that rod limits the wheel travel in rebound. Can anyone explain me of does it affect the weight transfer? and how can I calculate the new weight transfer?.
Thanks.
Best wishes.
Charly
Old 10-23-2006, 04:14 PM
Chiquae07's Avatar
Chiquae07 Chiquae07 is offline
Send a message via AIM to Chiquae07 Send a message via MSN to Chiquae07
Re: chasssi Spring preload
i beleive this would best be put into the car technical section of the forum...
2008 Mazda 6 ATX 2.3 Liters of Slowness
For those 9 seconds it takes me to reach 60mph, will be the most fun ill have in this car.
Old 10-23-2006, 04:57 PM
chevytrucks92's Avatar
chevytrucks92 chevytrucks92 is offline
Well, a car that has a 4-link rear suspension has that "rod" that you turn to set the preload. The idea is to stop cars from bringing one of the front tires higher then the other. So if you had a car bringing the left front tire, then you'd preload the right rear. It doesn't help though, or atleast it never helped us. I think you want as little preload as possible. Too much will casue the car to weave on top end.
You can ask 5 different people what this should be set at, and you'll get 5 different answers though.
The best thing to do IMO is to adjust one of the shocks instead of messing with the preload of the suspsension.
And I think when you add in preload, it does transfer more weight to the right rear. I have no idea how you would calculate that though. I just know I've been told by adding preloading, you're "adding weight" to the left front tire, and when you take out preload, you're "taking away weight" from the left front tire.
**1966 Chevy II**
355 SBC, Turbo 400, 5.13 gear, IHRA Certified to 8.50 in the 1/4
Last Race (10-6-07) So its been awhile...
Dial: 6.77, RT: -.0001, 60': 1.4360, 1/8th: 6.7942 @ 100.65 mph
Fastest Pass of '07 (10-6-07)
60': 1.4360, 330': 4.3453, 1/8th: 6.7942 @ 100.65 mph
25 and in BIG TIME Debt Crew member #2
Deuce's Wild Racing: Take a Ride on the WILD SIDE
