Go Back   Automotive Forums Car Chat > Chrysler > General Discussion
Old 09-08-2002, 05:04 PM
UrbanConfeder8 UrbanConfeder8 is offline
Send a message via AIM to UrbanConfeder8
Question Brake problems with the '76 New Yorker
I was wondering if any of you knew anything about the brake system on this car. The brakes lose pressure when you press and hold the pedal. It bottoms out, and the brake light comes on. This happens, yet the car leaks no brake fluid and the master cylinder appears to work normally. I was thinking the problem is the brake booster unit. Also, when I press the brake pedal with the engine off, I hear air escaping. I don't know if this is normal or not, but I thought I'd mention it. I would think that any brakes work on the same principles, but then again, I've never had to work on this type of thing. Any ideas?
Thanks,
Jon
:ylsuper
Old 09-11-2002, 10:02 AM
Sci-Fi's Avatar
Sci-Fi Sci-Fi is offline
Sounds more like a bad master cyclinder than anything else.
Old 03-28-2005, 03:55 PM
x03Mach1x x03Mach1x is offline
Re: Brake problems with the '76 New Yorker
secondary seal in the master cyclinder is bad
Old 06-07-2005, 04:15 AM
E38_Charger E38_Charger is offline
I definately agree with them but just so u know if it was the booster it would be a harder pedal, cos the boosters function is to boost/assist in pressure applied to the brakes, thus making the pedal softer.
Just a bit of handy info.
brake problems with 2002 ram air TA PTS 2002TA Camaro Discussions 1 02-15-2005 02:56 PM
new problem with the Lumina karaz Lumina 4 11-23-2004 08:10 PM
Big problems with the brand new Passat. . .anyone have any ideas? kraynek Passat 1 12-29-2003 10:46 PM
