Go Back   Automotive Forums Car Chat > Pontiac > General Discussion
Old 10-22-2006, 08:04 PM
guitarmaster005 guitarmaster005 is offline
rear differential question
how do you check the oil in the differential? i dont know how much i have in it cause its leaking but i dont know if its leaking bad or if its just slowly been leaking out over the years. also, what kind problems would i experience if there wanst enough fluid in there? and finally, what type of oil would i put in there?
Old 10-23-2006, 01:48 PM
xeroinfinity's Avatar
xeroinfinity xeroinfinity is offline
out saving the world
Re: rear differential question
whats the car and motor?
that would probly help alot.
1999 Grand Am SS 3.4 OHV
Old 10-23-2006, 11:07 PM
69goatfarmer's Avatar
69goatfarmer 69goatfarmer is offline
Usually there is a plug somewhere on differential that you remove to put fluid in. If you remove the plug and can stick your finger in there and touch fluid then there is enough in there. If you can't touch fluid put the correct type fluid in that hole until it runs out then it is full.
58 Cushman Scooter
69 GTO Conv 400/4sp
66 GTO Hardtop 428/Auto
75 Honda CB550
04 Grand Prix GTP Comp G
Old 10-24-2006, 09:17 AM
thier is a couple different plugs used here.
One is just a black rubber plug,
and the other would screw in, use a 3/8 ratchet drive to unscrew this type of plug.
