Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 10-22-2006, 06:38 PM
surferfletch surferfletch is offline
diff bolts needed torquing
Found a small puddle today back there. I thought the pinion seal was getting worse, but the cover bolts were just loose. It's been 6 weeks, I think, since I did the diff service, and I thought I'd torqued the bolts enough, but I guess not. Maybe I was afraid of breaking one... Anyway, it's worth chacking out - I know a few others did the service at the same time...
1997 Isuzu Rodeo LS 3.2L V6 SOHC 4L-30E Dueler Alenzas 4x2
1997 TJ Sport 4.0L D35 rear 5 spd 31" Dayton Timberline ATs
1996 VW Jetta GLS 2.0L 5 spd
Old 10-22-2006, 08:12 PM
Gizmo42's Avatar
Gizmo42 Gizmo42 is offline
Re: diff bolts needed torquing
So far no leaks from mine, but I did mine a couple weeks later. 25 ft lbs seems to be working ok for bolt torque.
--Dave
1999 Rodeo LS 3.2 4x4 5 Speed
32x11.50-15 BFG T/A KO
3" Lift - Rancho 9000x
Rear No-Slip Locker
Flowmaster 2.25" 50 Series
There is a very fine line between "hobby" and "mental illness." - Dave Barry
Old 10-22-2006, 09:23 PM
amigo-2k amigo-2k is offline
Isuzu Guy
no leaks here and the 2 bolts I broke off are holding in there.
-Ryan
Isuzu Moderator
Car Show Tips
Operations manager with a results-driven passion for process improvement
FAQ 98-04 Isuzu Rodeo, Rodeo Sport, Amigo, Trooper
SOLD - NOV2015 - 2000 Amigo, V6, HT winter, ST summer, 2wd
Old 10-22-2006, 10:59 PM
jcb18 jcb18 is offline
I actually drained and filled my diffy a couple weeks ago. I bought a rockcrusher cover for about $60 and it came with all new grade 8 bolts. This was the first time I'd ever done this service and I haven't had any leak problems.
My guess is you could find the right sized grade 8 bolts at home depot or lowe's to replace your stock bolts and not worry about breaking bolts again. The previous owner of my rodeo must have lived in a snow belt state because every bolt in my undercarriage snaps if I try to take it off so anytime I take out a bolt (or snap it and have to drill it out) in the undercarriage I replace it with grade 8 if possible.
1999 Rodeo V6 4WD
Old 10-23-2006, 12:47 AM
Tom01Rodeo Tom01Rodeo is offline
I serviced mine over 2 years ago and no leaks. Can't remember if I used the gasket or rtv or a combination of them. Also didn't have any broken bolts. How many of you 4WD owners have changed the front diffy fluid? Its relatively painfree compared to the rear. Next on my list is to somehow get the old fluid out of the 4WD engagement device on the front diffy and put in some synthetic. I had trouble last year getting it to go into 4WD mode the first time.
Old 10-23-2006, 01:42 AM
Ramblin Fever Ramblin Fever is offline
On my '91 Rodeo 4x4, I changed out the front diffy yearly - sometimes twice/year.
That truck definitely got use of it's 4x4 capabilities though; and it seen it's share of loading/unloading the boat sometimes on a sandy beach, sometimes nose into the water. Not too mention having driven down into mine-shafts, riverbeds, deep sandy pits and up onto the flat-tops.
Man that was a fun rig! We bought that thing when no one else knew what a "Rodeo" was, we used to tease that we were going to make the next Isuzu commercial in "Going Further".
It was so cool to pull up into a gas station or parking lot and get the strangest looks - everyone knew what an Isuzu "Trooper" was, but the Rodeo styling was classy and different.
And I can remember the first couple years of registering/renewing it's plates, "you drive a WHAT?"
1997 3.2L V6 Rodeo
32" Yoko's, 16x8 MB Wheels, 2" lift, Brushguard, KC Fog's, Loadwarrior Rack
On it's way to 185k strong
2004 3.4L Tacoma TRD off-road 4x4 Double cab
32" Yoko's, Westin Bull-bar, KC Fogs 60K miles
