Go Back   Automotive Forums Car Chat > Dodge > Dakota
Old 10-22-2006, 05:50 PM
dulley dulley is offline
rear wheel shudder
i have a 93 v-6 with a automatic and posi. rear end ,when you take off the one wheel will jump up and down ,the left wont .but when you start off slow it doesnt do it .someone told me it can be the converter ,but i think it is the rear end .can anyone help me with this matter. thanks
Old 10-22-2006, 08:29 PM
440dakota 440dakota is offline
Re: rear wheel shudder
what you have is a rear end with a limited slip differential. it is not an open diff and it is not a complete detroit locker setup. basically, when your on the gas it locks the rear two wheels so that they spin together. when your not on the gas a lot, they spin as an open diff. allowing you to take a turn or whatever. the problem is when it's locked, they want to spin the exactly the same. however, uneven tire pressure or turning slightly or whatever forces the wheel to skip on the pavement breaking traction and causeing the wheel to hop. hope this cleared it up.
Old 10-22-2006, 08:42 PM
i do have two different brands in the back but the same size and the air pressure in them. so what your saying is that if one tire is a little bigger it will screw the rear end up and make one wheel skip,like putting two different size tires on a four wheel drive.
Old 10-23-2006, 04:05 PM
i changed the two back tires ,made sure they were the same size .and the shaking is still there .i open the hood and notice the motor shakes too.could it be the t.c
Old 12-07-2006, 07:39 PM
rhandwor rhandwor is offline
Did you check the rear wheel bearings do they make any noise. The have an additive you could try for these rear ends. Check your universal joints for wear. Look at your motor and transmission mounts. Put the truck on jack stands and have somebody run slowly in gear watch for any unusual noise.
