Old 10-22-2006, 05:33 PM
Haparyan Haparyan is offline
Electrical Problem
My windshield wipers go on when I use my left turn signal and my headlights. In addition, they will also go on when I turn on my A/C. I removed the wiper fuse which partially solved the problem but now my left headlight does not work. I replaced the headlight but it is still not working. Can anyone help?
Old 10-22-2006, 07:19 PM
jgr7 jgr7 is offline
Re: Electrical Problem
Sounds like it could be a bad ground connection. These things can be very hard to find. Best to start at the battery and check all connections that you can find, clean and tighten.
Jeff
Old 10-23-2006, 03:27 PM
Do you think it could be the Combination Switch?
Old 10-23-2006, 03:40 PM
I once had my Timing Belt, Water Pump, etc. replaced and the problem was temporarily fixed but it returned after about 3 months.
Old 10-23-2006, 08:11 PM
That would lead me to a bad connection as they may have had to disconnect something to do that work. Start with the Batt and then look at what might have been disconnected with the work done.
Old 10-24-2006, 07:52 PM
n8zdogg n8zdogg is offline
Bad ground somewhere - I don't envy you, these things can a royal PITA to find and fix
