Old 10-22-2006, 03:08 PM
funkin jeep funkin jeep is offline
Question smells like burnt rubber
I just purchased a 97 cherokee good shape execpt the interior smells of burnt rubber mostly from under rear seat i've shampooed entire truck and it's still bad any help would be greatly appreciated
Thanks John
Old 10-22-2006, 05:43 PM
1996Chreokee 1996Chreokee is offline
Re: smells like burnt rubber
Look under the vehicle and make sure that the under coating has not peeled off from the underside and is laying on the exhaust... If it is just cut it away and get some under coating in a can and re seal...let us know
Old 10-22-2006, 06:25 PM
heat shield over muffler looks clean and intact so does the undercoat I dont smell anything burning when the jeep is running or see any smoke the paint under the carpet looks good but the foam on the bottom of the rear seat has a smokey like residue in spots its been out of the truck two days hosed shampooed and still smells like rubber
Old 10-22-2006, 07:14 PM
AlohaBra's Avatar
AlohaBra AlohaBra is offline
Cool Re: smells like burnt rubber
Are you saying it is from the interior of the car? Take the rear seat bottom out completely for a couple of days to see if it will deodorize. (Sorry, I just read that you had done that.) You might have to replace it. You can go to a detail shop and see if they have an ozone machine for deodorizing.
Old 10-22-2006, 08:52 PM
Next I may remove the rear deck liner to see if the odor clears from the interior it tucks down under the rear seat and if that works I may replace them both ....I am curious what may have caused this. The ozone machine/detail shop sounds like a really good idea soap just isn't working or any sprays
Old 10-23-2006, 08:20 AM
fredjacksonsan's Avatar
fredjacksonsan fredjacksonsan is offline
Caution: Monkeys bite!
Send a message via AIM to fredjacksonsan
Knew a guy whose exhaust was touching the bottom of the floorpan, his seat got hot and burned. Make sure nothing's touching underneath that's hot. Even if the heat shield is in place, if the muffler or other exhaust parts are touching it there could be some heat transfer.
Ours: 2020 Jeep Wrangler 2.0, 53k
2013 Toyota FJ Cruiser, 84k
Kids: 2005 Honda CRV, 228k
