Go Back   Automotive Forums Car Chat > Mazda > B-Series/Bravo/Bounty/Drifter
B-Series/Bravo/Bounty/Drifter Bravo is the Australian vesion, Bounty the New Zealand version and Drifter the South African version.
Old 10-22-2006, 10:47 AM
bstrom1953 bstrom1953 is offline
B2000 won't idle after warm up
My 1986 B2000 won't idle at all after warm up. When it starts cold, the choke is set and it warms up fine. As soon as it is warm and the throttle goes back to normal, it dies almost like turning off the key. It drives fine, but when you come to a stop the motor dies. I am looking at the EGR valve now but haven't come to any conclusions. Help.
Old 10-23-2006, 07:21 AM
ChoochCharlie's Avatar
ChoochCharlie ChoochCharlie is offline
Re: B2000 won't idle after warm up
I have about the same issue.
To cope, I dialed the idle up to about 1000. She idles then.
My problems are - leaks at exhaust, need fuel pressure regulator for the new Weber Carb, and needs a tuneup. I do not know if one of these is the culprit.
My suggestions - If you still have the stock carb, look for a vacuum leak. Exhaust leak? Clogged catylitic converters?
Old 10-23-2006, 09:26 AM
This idle problem started very abruptly. It was running fine. When I came up to a stop, the motor died...been the same since. I have ruled out the EGR valve. It is closing properly. In fact, I took it off and plugged the intake port...still died after warm up. I'm going to check the idle switch next. Maybe it's open and not telling the control module that the throttle is at idle position.
Old 12-06-2007, 12:45 PM
emoi1776 emoi1776 is offline
i have the same problem, did anyone figure out what the solution is?
Old 12-06-2007, 04:01 PM
Sorry, haven't solved it yet because the problem disappeared one day. It runs normally now. I had to go back and reset the idle speeds for choke and no-choke operation. I had the idle speed raised high trying to keep it running.
bstrom1953
Old 07-07-2008, 09:22 AM
lou_daly lou_daly is offline
hi
just wondering if anyone solved this problem
i have the same thing
put the b2200 into a former b2600 then the problem started
thanks
lou
Old 07-09-2008, 02:50 PM
bypassed the problem by removing the plunger and spring from the slow idle solenoid
let me know if anyone wants the details
lou
Old 07-09-2008, 05:38 PM
bearfoot56 bearfoot56 is offline
sounds like u need 2 rebuild the carb the top gasket is notorius for coming lose and creating a leak u may try tightning all the screws but chances are it will still need 2 b rebuilt good luck
