Old 10-21-2006, 11:19 PM
Loekee75's Avatar
Loekee75 Loekee75 is offline
Send a message via Yahoo to Loekee75
Question Very odd tank fill-up problem
My dad's 91' Lesabre Custom has just started giving him quite a strange problem at the pump: when filling up, the pump will ckick off, as if the tank were full. At the initial time he attempted adding gas, he only had about 1/4 tank in there. He thought maybe the pump he was using was defective, so he tried using another only to get the same problem. He had to constantly pump the handle with his had because it'd constantly shut off within 2 seconds.
For an added check, he tried filling up at a different station, but the problem persisted.
He also noted that there is a gas smell around the car in his driveway.
I was thinking there must be some back pressure (for unknown reasons) causing the gas pumps to sense a full tank. Any ideas? About a week earlier I had replaced his fuel filter and pcv valve, could this be relevant to the problem? I started the car and checked for leaks around the filter after replacing it, and none were visible. I've replaced dozens of fuel filters but never had nor heard of a problem like this! Thanks all!
http://www.cardomain.com/ride/2653398
1992 Buick Park Avenue (Daily driver)
2001 Saturn SL1 (gas saver)
Old 10-22-2006, 10:29 AM
buckroo buckroo is offline
Re: Very odd tank fill-up problem
You need to check for an obstruction in the neck of the gas tank.
Old 10-22-2006, 10:40 AM
ChemMan ChemMan is offline
I've had that problem on occasion before. I found that not putting the nozzle in all the way helped.
2010 Mazda CX-7 2.5L 12000 miles
2003 Chevy S10 Extreme 4.3L 57000 miles
1995 Buick Lesabre Custom 86000 miles RIP
2002 Pontiac Sunfire SE 130000 miles RIP
1997 Pontiac Bonneville SE 91106 miles Totaled by attempt to steal the car!!
R.I.P. 1978 Ford Fairmont 83000 miles
Old 10-22-2006, 11:34 AM
Smith1000 Smith1000 is offline
Sounds like a plumbing problem. It must be air-locking. I have had that problem on some older vehicles. There is a separate, smaller hose that goes from the neck to the tank. It is for the purpose of releasing the air, so that the tank will fill, like plumbing air/roof vents on a house. The air vent hose may be kinked or blocked as mentioned, so that gas can't enter the tank and the pump kicks off. It may help to hold the pump up higher so that it can vent through the fill tube. I think the opening is fairly small though and that may not improve things much. Look for a kinked air vent hose or something is in the tube blocking the air flow.
Old 10-22-2006, 12:31 PM
Loekee75's Avatar
I'll look into everything mentioned. Thanks all!
