Throttle Body on 99' 3.2L V6 Rodeo
I just cleaned the throttle bodies on my 99' 3.2L V6 Rodeo. I removed the air intake duct first. Next I used a tooth brush to scrub the inner workings of the throttle body, mainly the ‘butterfly’ and walls of the body. Sea foam was my solvent of choice. I followed that up with a few shots of carb-cleaner and wiped the grease out using a paper towel. I buttoned everything back up and started the engine. It ran for about 5 min. I was surprised that it ran rough. Did I do something wrong? The CEL didn't come on. Perhaps I should just let it run for a while and put some fuel additive in to help out? Could I have pushed the tooth brush back too far and damaged somthing? Any suggestions would be appreciated.
Re: Throttle Body on 99' 3.2L V6 Rodeo
Nothing wrong. But, do jump in it and take it for a good 25-30 mile drive preferrably today to help wash out all that goo before it sits for the night.
1997 3.2L V6 Rodeo 32" Yoko's, 16x8 MB Wheels, 2" lift, Brushguard, KC Fog's, Loadwarrior Rack On it's way to 185k strong ![]() 2004 3.4L Tacoma TRD off-road 4x4 Double cab 32" Yoko's, Westin Bull-bar, KC Fogs 60K miles
I went for a short 20 min. drive last night. By the time I got home it was purring like a lion. I just hope this helps out with my 13.5 mpg I have been getting. I'm putting on new tires sometime this month, I jut need to figure out which brand first. Hopefully that will help out. Thanks again for your quick response. -Derek
If you're looking for greatest mpg - stick to highway/all-season tires unless you live in an area or travel to areas where you might need all-terrains.
Myself, my Rodeo came with a good set of LONG lasting highway tires, i.e BFG Long-Trails, and they lasted a LONG time, got excellent gas mileage with them too. But, they actually had to be replaced about 10k miles before needing too, as they had soooo many holes/punctures from traveling through the desert/mountains on off-road adventures. Needless to say, every truck/suv of mine gets a set of all-terrains. Not too bad though, I'm running Yokohama Geolander's now in the 265/75 R16 size, which averages me 17-18 city/21-23 highway. For your gas mileage improvements, take a look at your air filter, pcv valve, fuel filter, and report back here on what your tire air pressure is now. Your gas mileage seems a little low to me, you should be getting at least 15mpg, unless you've got some BIG tires and a lift. Tire pressure can be your friend or enemy here, whether or not you have the OEM size or aftermarket.
I run 35 psi in my tires. For the last year I've gotten a steady 15.5 mpg just driving to work and back but for some reason on this last fill up I got 17.5 mpg. My commute is only 8 miles each way with half city and half slow or stop and go highway so not the best for mileage. With a combination of highway/trail I've been getting around 19 mpg.
For the price I like these dayton timberlines. Good in rain and snow, no problems so far offroad, and half the price of BFGs. They dont seem to hurt gas mileage either though I put them on as soon as I bought the rodeo so nothing to compare to.
--Dave 1999 Rodeo LS 3.2 4x4 5 Speed 32x11.50-15 BFG T/A KO 3" Lift - Rancho 9000x Rear No-Slip Locker Flowmaster 2.25" 50 Series There is a very fine line between "hobby" and "mental illness." - Dave Barry |
If you're looking for highway tires, personally I'd go for the Firestone Destination A/T (they're marked an all-terrain, but primarily for highway use).
Otherwise, if you're looking for all-terrain's, personally as long as you stay away from BFG AT KO's and Goodyear Wrangler RT/S, I think you'll be ok. Goodyear has some newer at's out that might be good; my Dodge will be do for tires at the beginning/end of next summer, not quite sure just yet as to when, but, they may be replaced by Firestone Destination A/T or Goodyear wrangler MT/R's. But, that's only because the original Geolander AT II's are being discontinued; and they are wanting a $$$$ for the new Geolander ATS that superceeds the older ones.
