Old 10-21-2006, 05:56 PM
rockethobbit rockethobbit is offline
96' V6 trouble starting
I have a 96' V6 S-10 that has trouble starting. The battery is new so it has lots of power to turn over, but it takes a few turn overs and pumping gas to get it to start.
Once it starts it runs perfectly.
Can someone suggest items to check that could be causing this?
Thanks.
Old 10-22-2006, 02:07 AM
DelCoch's Avatar
DelCoch DelCoch is offline
Re: 96' V6 trouble starting
Do a search on this board for "Hard Starting". There have been several posts in the last week or so.
Old 10-22-2006, 02:30 AM
edbrycem edbrycem is offline
kinda sounds like a fuel pressure regulator not holding prime when shut off.
Old 10-22-2006, 12:46 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Thanks.
1.) Don't EVER pump the at any time. If it isn't starting, pumping does nothing but flood a fuel injection engine.
2.) Do a tuneup.
Fuel filter
Spark plugs AC Delco Platinum only
Cap & Rotor
Air Filter
PCV Valve
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 10-22-2006, 01:10 PM
maxwedge maxwedge is offline
A990 racer
WQelcome to AF. In addition you may want to scan it and check for proper coolant temp sensor operation and check the fuel pressure during cranking.
