Old 10-21-2006, 02:09 PM
usmcscout123 usmcscout123 is offline
Send a message via AIM to usmcscout123 Send a message via MSN to usmcscout123 Send a message via Yahoo to usmcscout123
rear end differential
Someone told me there is fluid within there that you are suppose to change? How often should you change that out?
Old 10-21-2006, 03:38 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Re: rear end differential
Every 60,000miles would be best.
Suck it out with a pump and refill with 80w90 or synthetic 75w90.
The amount to fill should be in your owner's manual.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 10-22-2006, 08:21 AM
Blue Bowtie's Avatar
Registered Offender
That's good advice - If the axle has been properly service at least once before. Many Saginaw (corporate) axles come assembled with a gasket which covers the oil return holes from the ends of the axle tubes. This is more common on the 8½" axles, but is worth checking on ant of them.
Notice that the replacement gasket has slots to uncover the return holes, whereas the OEM gasket does not. Oddly, they USED TO have these holes. Once the correct gasket is installed, subsequent axle oil changes can be accomplished with the suction gun/refill method, so long as you're certain the suction gun is removing all the old oil.
Old 10-22-2006, 09:36 AM
BlazerLT's Avatar
AF -Advisor
I thought our axles were sealed.
Old 10-22-2006, 07:35 PM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
I was taught to loosen the bolts on the cover and allow the fluid to drain out. Then tighten the bolts back up and fill.
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html
"What we've got here is a failure to communicate"
Old 10-22-2006, 07:38 PM
BlazerLT's Avatar
AF -Advisor
In most cases you can't do it that way seeing there is a gasket you have to replace.
Old 10-22-2006, 07:47 PM
Brian R.'s Avatar
Resident Chemist
We never replaced the gasket. No problem with leaks - at least as long as you weren't careless and tore it.
Old 10-22-2006, 07:58 PM
Registered Offender
AFAIK, they are still sealed on the outer ends, like they always were. However, they are not sealed at the inboard ends of the axle tubes, which allows lubricant to eventually work its way to the outboard bearings by a little splash and a little G-force. The notch is just another means for oil reaching the outboard ends to drain back to the main gearcase area/reservoir.
Old 10-23-2006, 06:42 PM
sreve sreve is offline
silicone has worked for me.
Old 10-23-2006, 10:36 PM
BlazerLT's Avatar
AF -Advisor
True, but what I meant is that you have to redo the seal when you ever pop it open.
