Go Back   Automotive Forums Car Chat > Saturn > SC/SL/SW
Old 10-21-2006, 01:54 PM
nuwt's Avatar
nuwt nuwt is offline
Send a message via ICQ to nuwt
Exclamation 99 SL is hard to steer
I havent hit anything, but I have noticed that my car is hard to steer. It is best described as stiff steering. If you turn out from a road or driveway and let go of the steering wheel it will stay, I have to turn it back to straight position. It is manual steering and the car has a little over 120000 miles on it. Any ideas? I looked under the car and cant see any visible worn or damaged parts. I havent had a front end alignment in years but the car runs straight and it doesnt wear out the tires unevenly. I looked through some other literature and found it may be the front end parts are wearing out. Has anyone had similar problems?
Laugh all you want!!!! I have NO Payments!!!
Old 10-24-2006, 12:40 AM
Cat Fuzz Cat Fuzz is offline
Re: 99 SL is hard to steer
Here's what I would do:
Jack up the front and test the steering. With no weight, it should steer easily. If its still stiff, I would take loose a tie rod end and see if it gets easier to turn, if not, take the other end loose and test again. If its still hard to turn, you have a bad rack and pinion if it's really easy to turn, you probably have bad ball joints, or bad strut bearing plates. It's a process of elimination. The tie rod ends are the easiest to check. Seems like something has worn out and is tightening up.
Old 10-24-2006, 06:33 PM
nuwt's Avatar
Thanks, I will do that as soon as I have the weather and time.
Old 10-25-2006, 09:00 PM
nuwt's Avatar
I have been driving the car daily and today when i made turns it was as if there was gravel in the steering column. Is there bearings in the column?
Old 10-29-2006, 05:50 PM
saturnspeed_12's Avatar
saturnspeed_12 saturnspeed_12 is offline
dead rack? never known anyone to replace a rack, but sounds like maybe something is up with yours.
Ian
Saturn Tuners Club-OH Chapter President
1993 Saturn SC2 rebuild project for dad
1995 Saturn SL2 current daily driver /w a lot of work
2007 Chevy Cobalt injen cai, full lsj exhaust, dc sports fsb, progress springs and rear sway bar, enkei wheels/hankook rubber --*boost in progress
