ABS and no Odometer reading
Before i start spending a fortune at the garage ...
Today after doing my daily routine I noticed after my last stop that ABS light was on and Odometer reading was -------- Any suggestions where to start ??
Re: ABS and no Odometer reading
Thanks checked fuses and sure enough it was # 10 fuse
One thing, I put another 10amp fuse in and it popped, So i put a 15amp fuse in .. seems to be ok now I just hope i dont cause another problem with this solution |
It needs to be corrected before you really start spending a fortune at the garage... |
Check and make sure there is no leaks around the area... Post back and let us know what you find. Hope this helps, Gary |
A leak point to be concerned about would be the pressure switch that is located on the bottom of the master cylinder.
If leaking.....it needs to be replaced.
Moderator for Ford Windstar room only Links to my pictures, intended as an aid, not a replacement for, a good repair manual. 1996 3.8L Windstar http://www.flickr.com/photos/4157486...092975/detail/ 2003 Toyota Sienna pictures (not much there yet) http://www.flickr.com/photos/4157486...781661/detail/ |
Thanks. |
Gbenga,
The Brake Pressure Switchs are faulty on these Windstars (and Other Fords). I just replaced mine on my 99 WS. They connect to the bottom of the Master Cylindar. First, purchase a new one (on-line is cheaper than the Ford dealers) cost should be around $ 25. Second, disconnect the old one from it's connection. With an adjustable wrench turn the switch counter-clockwise (the wrench sb on the nut just below the base of the Master Cylindar) or (Just above the part that shines). Once loose, take off by hand but place a small cup (enough for a couple ounces) to catch the small amount of brake fluid that will come out once the switch is removed. Only a couple of Oz will come out. Put in the new one by hand and tighten by wrench. Make it snug but don't over tighten. Reconnect the switch. Takes about 15 minutes. Some remove the air filter and housing to have more room, but you may not have to. AvalonJohn Last edited by AvalonJohn; 05-16-2007 at 03:38 PM. |
I have pictures posted that the link in my signature will take you to.
There are a number of pages of pictures..... In those pictures, I show the replacement process. Take note that the FORD part numbers that I show are for my '96....and could have changed since then.....however, the parts people at the dealership will have no problem with getting you set up with the correct part.
Thank you all good people in AF!
The pressure switch was changed and all the problems solved. Whaoh! I am so grateful. Gbenga |
