Go Back   Automotive Forums Car Chat > Nissan > 240Z | 260Z| 280Z | 300ZX (Past Z Cars)
240Z | 260Z| 280Z | 300ZX (Past Z Cars) The original Z cars - ones that started it all.
Old 10-21-2006, 11:57 AM
Eclipsewhipping Eclipsewhipping is offline
differences between NA rear end and TT
OK... I just talked to a rep from NISMO and he told me that the na and tt z32 use pretty much the same rear end set up, the differntial is the same its just the gear ratio is different,
nismo sells a ring and pinion gear set that is 4.111 and he told me that it will work for both the tt and the NA,
what do you guys think about this? for some reason i dont think he is telling my the truth. but maybe im wrong, can some one please help me out
Old 10-21-2006, 08:22 PM
k3smostwanted's Avatar
k3smostwanted k3smostwanted is offline
Z Cars Fanatic
Send a message via AIM to k3smostwanted
Re: differences between NA rear end and TT
i do NOT think the gears are interchangable between N/A and TT. i dont remember what the difference is but i am pretty sure i remember reading some controversy about the Leader gears not going into the N/A rear end.
and i am pretty sure the N/A differential cannot be swapped into a TT with some extensive modification.
broke may have to correct me if i am wrong or maybe clarify. i dont feel like researching it.
ZedEx Crew Member #4
Old 10-22-2006, 02:55 AM
Broke_as_****'s Avatar
Broke_as_**** Broke_as_**** is offline
This is correct. Why you would put 4.10 gears in a 4.083 rear end I don't know but whatever.
The NA uses the R200 housing and the TT the R230. Among the differences are the axles, ring gear diameter, the output flanges, some of the subframe mounts...etc. This is why swapping the NA rearend into the TT is quite the hassle:
http://twinturbo.net/net/viewmsg.asp...&msg_id=546490
Don't I always you lazy bastard?
Anyway, as you probably saw over on TT.net just going by what is in the Nismo catalog they don't appear to sell any gear sets that will fit in the R230. However there was another post from Mark Leader about another run of 4.10 gears coming up in early 2007. No prices, dates or amounts available have been set but drop Specialty Z a line to let them know you're interested.
1989 240SX Fastback. . . . . . . . . . . . . . . . . . . . . . . . . . . 1995 300ZX Twin Turbo
Warning: Objects in mirror aren't as fast as they thought they were.
Old 10-22-2006, 03:44 AM
Z Cars Fanatic
it is greatly appreciated as i am very lazy.
Old 10-27-2006, 04:46 PM
Hodo Hodo is offline
"The NA uses the R200 housing and the TT the R230. Among the differences are the axles, ring gear diameter, the output flanges, some of the subframe mounts...etc. This is why swapping the NA rearend into the TT is quite the hassle:" ----- Broke
Well that actually answers my latest question. Will a Q45 rear end work with my VH45DE swap...... its a R200 (3.528:1) So that would be a yes. hmmm..... back to the garage.
Finaly got pics of my car....... after I washed it of course.
Old 10-27-2006, 06:37 PM
DeleriousZ's Avatar
DeleriousZ DeleriousZ is offline
Send a message via MSN to DeleriousZ
you're still working on that eh hodo?
ZedEx Crew Member #6
1988 300zx turbo 5spd. 3" mandrel exhaust, filter, afco rad, e-fan, poly engine mounts, mbc at 8.5 psi, turboxs rfl-h bov, gutted plenum, etc.
blown turbo, under construction.. gt35 coming.
Old 10-28-2006, 09:29 PM
Yea had a bad year at work.... made just enough to survive on, nothing more nothing less. Starting a new job at a Nissan Dealership so things are looking to turn around.
Old 10-28-2006, 09:33 PM
DeleriousZ's Avatar
that sucks man, good to hear things are looking up!
