Go Back   Automotive Forums Car Chat > Kia > Sephia
Old 10-21-2006, 09:39 AM
keeperman keeperman is offline
fuel filter 2001 kia sephia
How do I change the fuel filter on my 2001 kia sephia?
Old 02-09-2007, 09:37 AM
p_nitefly p_nitefly is offline
Re: fuel filter 2001 kia sephia
you need to remove the back seat bottom (it should pull right out, this will expose the fuel pump access). then start the car and disconnect the electrical lead from fuel pump and let engine die, now your fuel system is vented, this should minimize fuel spraying when you unhook lines. the filter is under the car about mid-way between engine compartment and fuel tank (i forget which side of car it's on), all you need to do now is remove a couple of mounts and disconnect the fuel lines, then put a new one in and reconnect your fuel pump and you're ready to go.
