Go Back   Automotive Forums Car Chat > Nissan > Altima
Old 10-21-2006, 01:46 AM
jimls jimls is offline
keyless system for 99 Altima
Does anybody know that is every 99 Altima GXE come with remote control system. Because I just got a used one, but no remote fob. So is there any way that can find out if my car equiped the remote control system. Thx
Old 10-21-2006, 06:12 AM
FixUrNissan's Avatar
FixUrNissan FixUrNissan is offline
Re: keyless system for 99 Altima
Originally Posted by jimls
Does anybody know that is every 99 Altima GXE come with remote control system. Because I just got a used one, but no remote fob. So is there any way that can find out if my car equipped the remote control system. Thx
i don't think i have seen one with out it. Check for a security light on left side of dash , if no then you may have just keyless entry.I believe it will have one or the other.
Old 10-21-2006, 04:57 PM
thanks. And i bought a remote fob from ebay. but it didn't work. So i don't know what the problem is. And how can i know the FCC ID of my car remote system. and i can't find any security light on the dash. if i don't have security system, is it the same way to program a remote? thanks for help
Old 10-22-2006, 07:51 PM
Do you know how 2 program the remote? Did you do that first before you tryed it on your car?
Old 10-22-2006, 10:33 PM
yes. i know. the seller sent me the instruction also. And i followed it. but not work.
Old 10-27-2006, 06:14 AM
What does it say to do , and I'll tell you if it's the right way
Old 10-27-2006, 09:27 PM
Nissan keyless remote programming instructions:
IMPORTANT: Before entering programming mode, have in possession all of the
transmitters you will be using on the vehicle. Once you program the
transmitter, all previous codes will be erased from the memory. The other
transmitters will not be functional until you program the transmitters
again.
1. Close and lock all doors with the driver’s side power lock/unlock
switch.
2. Insert key into ignition and remove it from the ignition key
cylinder at least six times within 10 seconds. Your Hazard Lamps will flash
if you have performed this step successfully. NOTE: Withdraw key completely
from ignition cylinder each time. If this procedure is performed too fast,
system will not enter programming mode.
3. Insert key into the ignition cylinder and turn to the ACC position.
4. Within 5 seconds, push ANY button on the remote transmitter. Your
Hazard Lamps should flash. NOTE: Do not press the button more than one time
in the above step. If the button is pressed more than one time, the
programming procedure will not be successful.
5. If there are any remaining transmitters (including the old ones),
unlock then lock all doors using the driver’s side power lock/unlock switch
and within 5 seconds, push ANY button on the next remote. Your Hazard Lamps
should flash. Repeat this step for each transmitter (including any existing
transmitters).
6. Turn the key to the OFF position, remove keys from the ignition,
unlock doors using the driver’s side power lock/unlock switch and open the
driver side door.
That's what they told me. Is there any problem? Thank you
