Old 10-20-2006, 08:27 PM
Cruize Cruize is offline
Flashing Engine Codes ???
Someone told me that I can flash engine codes on a 95 Blazer by cycling the key off and on three times. Does this work? I tried it without any success.
As far as I know, I've got the OBD I setup, but I don't have pin #6 in the Data Link Connector to jumper and get the codes that way.
Cruize
1992 Ford Escort GT, 5-speed - Now with an unlimited slip clutch! :sarcasm1:
1995 Blazer LS, 4x4, 4 door
1996 Pontiac Grand Am GT, 5-speed
1997 Suzuki DR650 ~54 mpg
Old 10-20-2006, 10:09 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Re: Flashing Engine Codes ???
No, it will not work.
If you have a computer on your passenger front tire wheel well, you will need an OBDII scanner to get the code.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 10-21-2006, 12:20 AM
ZL1power69's Avatar
ZL1power69 ZL1power69 is offline
GM S-Series Mod
if the computer is under the hood than you can't flash codes. you need an obd2 scan tool. autozone or advanced auto will let you use one for free.
2000 Chevy Blazer ZR2
Performance Mods: Numerous
Suspension Mods: Some, but not enough
Exterior Mods: Just Right
1987 Buick Turbo T Dark Red
Low 11 sec sleeper
.030 4.1 block, PT6262E, & other odds and ends....
My Cardomain
Old 11-21-2006, 09:07 AM
edlittlebus edlittlebus is offline
problem with fuel pump . replaced pump,filter,relay switch, still not getting enough gas to injectors,ican run fuel pump directly to battery s-10 runs fine. also not enough power to run anything at night everything dim truck runs rough this started befor pump went out
Old 11-21-2006, 09:12 AM
not familier with diagnostic codes. im not a machinic but im not dense either. ican take offf and put on correctly just need instructions on how to. but like everyone else i dont have money to take to mechanic. s-10 chevy truck 1991
Old 11-21-2006, 09:22 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Well it is not a Dodge.
The key on 3 times does not work on a GM.
Have you got the old style diagnostic plug with pin A & B?
If so you jumper pin A&B.
http://www.troublecodes.net/GM/
MT
