Old 09-08-2002, 01:26 AM
BullShifter's Avatar
Shift Light Installed
91 Civic Si
Installed AutoMeter Pro shift light inside the center vent. It was an easy install. Took a while to figure out how to secure the light & proper placement since there isn't much room. I wiggled and finally found a place where no screws are needed. There is just a slight amount of pressure to keep is still. Found a place to pull the wires through & connected. MSD SCI box is mount just behind the glove box on the heat ducting & has a tach hook right on the side where the shift light can be connected if not using aftermarket tach.
:smoker2:
Old 09-08-2002, 12:13 PM
91civicDXdude's Avatar
did you buy just a shift light? if so, how much was it and where did you get it? im looking for a really really cheap shift light to modify and use as a VTEC switch
Old 09-08-2002, 12:26 PM
EFsleeper's Avatar
EFsleeper EFsleeper is offline
Send a message via AIM to EFsleeper
autometer shift lites come with pills that you plug into the light to tell it when to come on, I think they run about 80 bucks. My local Trak Auto store can order them.
Stop looking at my Autometer!
Old 09-08-2002, 02:34 PM
I ordered only the light from summit racing. The light was $65.00 & the RPM pills are $20 for a set. I went with 6,000rpm kit which included 6000 - 6200 - 6400 - 6600 - 6800
www.summitsportcompact.com
:bandit:
Old 09-08-2002, 09:14 PM
obsidian66 obsidian66 is offline
Im just starting to work on my civic, so i dont know tons about vtech and what not, when does vtech kick in? And what would the pros of the shift light being connected to it be?
Old 09-08-2002, 09:19 PM
plkelley's Avatar
plkelley plkelley is offline
Send a message via AIM to plkelley
I'm pretty sure VTEC kicks in at 5 grand but could be wrong. Whats the point in a shift light?
Old 09-08-2002, 10:40 PM
EFsleeper's Avatar
From what Ive been told VTEC activates at 5200 rpm. At least thats what my friends JDM B16a does. I have heard even higher numbers but from what ive seen and driven its around 52-5400.
The point in a shift light is to warn the driver or let the driver know that he/she has or is about to approach redline in that respective gear. Pretty useless if you ask me but I could use one considering my car has no tach and it very quiet. But if your car is loud I dont believe you should be using one since the motor is very audible. But its just another light to put on your dash. and hey its fun. I think someone should make a light that flashes like this:flash: that might be cool. no, I take that back it will be annoying, like those cell phone antennas that flash the same way. Ok enough ranting.
Old 09-08-2002, 11:12 PM
Melt's Avatar
Melt Melt is offline
Send a message via AIM to Melt
Activates at 5200 on the SOHC engines (d16y5, y8) and at 4700 - 4800 on a GSR.
AF Bay Area Crew
97 Toyota T100 xcab 3.4l v6 5spd 2wd
Old 09-08-2002, 11:26 PM
gunnmen01's Avatar
gunnmen01 gunnmen01 is offline
Send a message via AIM to gunnmen01 Send a message via Yahoo to gunnmen01
You can set a shift light to come on whenever you want, so it lights and you know to shift with out watching your tach.
gunnmen01
My other ride..... is YOUR MOM !!!!!!
Old 09-08-2002, 11:44 PM
id rather have a shift light hidden from view than a big ass 5" tach blocking vision.
installing a shift light Civic_D16Y5 '88 - '91 Civic | CRX | Wagon | Shuttlee 3 04-27-2005 01:37 AM
installed shift light with rpm activated switch now no tach reading help!!! B16Civic93 Let's get Technical! 0 06-27-2004 12:23 AM
Accord Type-R Shift Light Installation calumski Accord/TSX/Accord Hybrid 0 11-09-2003 07:35 AM
Help installing shift light.. SiZ '88 - '91 Civic | CRX | Wagon | Shuttlee 1 04-11-2003 01:53 PM
Shift light install 3rdcoast Car Audio 2 04-19-2002 12:27 PM
