| COMPLETELY off-topic Talk about anything other than cars. But you can't be mad and angry in this forum! |
Need Computer Help Mic...
Ok guy's/ girls I need some help with my computer the problem is with windows live messenger !
ok here is what is happening I go to talk to a freind who has just got a USED COMPUTER a older one anway we go and try get video and sound by using a video calling feature on msn now for some reason we can see each other but can not hear each other what could the problem be we have made sure the the mute is not on I am running XP and she is running windows 2000 PLEASE HELP !!! __________________
93" LINCOLN CONTINENTAL 69" BUICK RIVIERA 1988 MAZDA B2200 NEEDS HELPhttp://www.geocities.com/jjbannon81/69RIVIERA.html 1999 OLD ALERO
Re: Need Computer Help Mic...
What kind of microphone are you using?
ECNATSISER AL AVIV
If you don't have an external mic hooked up and if your minicam doesn't have one built in, you're not gonna have any sound
no mic = no sound
ECNATSISER AL AVIV
I KNOW THAT MY QUESTION IS HOW DO I CHECK ?? PS SORRY ABOUT CAPS !!
Go to the control panel. Somewhere in there should be the minicam. If there is no tab for "Volume", "Volume Out", "Microphone" or something like that, then you can bet theres no mic in it. Most minicams I've seen don't have a built in mic. Just buy an external mic, you should be able to get one for like $20
And if you know you're typing in all caps, why don't you just turn off caps lock?
ECNATSISER AL AVIV
just to make things clear I thank you for your help and ment nothing with the caps I am using a web cam logitech Im going to try and see if there is a mic now thanks again 00accord44 !! anything else you think may be usefull ?
if I can recall correctly.... windows messenger when first installed should have ran an audio check for microphone and speaker output... check the back of your computer to see if you have a mic input jack available and if a jack is installed, that is if it's a desktop. Most laptops thaat I have already have a mic on the keyboard top. Hope this helps
If you buy an external mic and you're running XP it should prompt you to start the install wizard as soon as it recognizes new hardware.
ECNATSISER AL AVIV
Thanks for the reply man
when she goes to update the messenger it will not let her why ? this is what it tells us when i try to send her a voice message "Amanda is using a version of Messenger that does not support Voice Clips."
They introduce a new version of msn messenger like every week so I don't know what the new version is or what features it has. I do know that the version I have (4.7) supports video and audio messaging. But I've never tried to use the audio, so idk how it really works.
Has she tried to just download messenger all over again instead of trying to update her current one? When I tried to view my friends webcam she got a message saying the same thing. I downloaded msn again and it worked.
ECNATSISER AL AVIV
Thanks for the help turns out that the mic that I was using was not working the way it should be so I went out and bought a new mic today thanks again for the help
You have to go into the control panel and select the logitech mic as the computers default mic, or it will try to use your sound card for mic support
To do this you have to go into the control panel, select sounds and audio, click audio and on the bar that says mic, you have to change it and tell it to use the camera mic. The one in the camera will work a lot better than any stand mic that costs less than 30 bucks. good luck. |
Did you actually read the whole thead before posting hotrod_chevyz?
He bought a new mic and the problem is fixed.
Yeah i read all that. I was simply telling him how to go in and set up a MIC inside his control panel, wich i didnt really see anybody tell him. He said the mic he had wasnt working properly, wich led me to believe he had one already, and maybe it wasnt set up right. If hes using a logitech cam they almost always have a built in mic with advanced settings available from the control panel, and usually are better quality than the cheap ones you will find on a shelf at the store.
