Old 09-08-2002, 12:09 AM
strodda strodda is offline
oxygen sensor
is it possible to clean the tip and reuse?? i was looking on kragens site, and a new bosch o.e. sensor was over $200.
they had a universal one without connectors for under $100. if i was to get that one, what would i need to do to make it usable? how would i wire it? im assuming it would be a huge hassle since its so much cheaper. has anyone had experience with installing a new one?
Old 09-08-2002, 01:00 AM
GTA's Avatar
GTA GTA is offline
Whee..
Mine was easy to install. But was also a lot cheaper. Mine cost like 60 bucks, with the connector. I would think you would be able to get the one without a end and splice it onto the old plug.
AF Bay Area Crew
RIP Melt
2008 Mitsubishi Lancer Evolution GSR
2007 Toyota Prius
I <3 and miss my 4g
Old 09-08-2002, 05:24 PM
yea thanks. i did a little more searching and i found that i can do exactly what you said. although i'd use just a single wire sensor, meaning that i wont be able to have it heated.
one more thing. i saw on ebay a couple ngk sensors, but none for my year. if i were to cut off the wires and splice just the single to the harness, would it work?? are all sensors threaded the same?
Oxygen Sensor sasheehan Almera | Sunny | Pulsar | Bluebird | Tiida | Versa | NX | Avenir | Tino | Stanza 6 04-01-2012 08:19 PM
Cleaning O2 Sensors CCMphysician Engineering/ Technical 4 01-15-2010 07:47 AM
97 camry V6 02 sensor help!! machinehead26 Camry/Camry Hybrid/Vista 3 10-25-2009 07:44 PM
is it weird my oxygen sensots voltage changes WHEN THEY'RE UNPLUGGED? bac512 Savana 0 07-29-2009 10:20 PM
o2 sensor danielgast46 F Series 0 03-15-2009 09:39 PM
