| Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible. |
Help with throttle response plz!
Hey guys, I've been working on getting this car back together (in sig). The car seems to idle fine and when I'm in higher rpms, it seems to run fine too... its just that when I try and give her just a little gas (like accelerating from a stop), it will either fall flat on its face or start surging. I've changed plugs (gapped at .030), I've changed wires, I've changed tps (used to be a cel), I've even changed the fuel filter. When I started working on the car there was old gas in it, I syphoned as much out as I could and filled up with new premium. So does anyone have any other ideas that I could check? BTW, there's no cel now that I've replaced the tps. Thanks in advance.
1990 GSX PTE SC6152e, tubular manifold, FIC 650's, wiseco/eagle internals, dsmlink, TRE tranny, Apexi dp and cat-back, Apexi EGT and Boost Gauges and Turbo Timer, Megan Racing FPR, Walboro 255 Pump and much more to come. |
Re: Help with throttle response plz!
One thread on this was enough man, don't make a double next time.
What plugs did you put in?
'92 3000gt SL Zoom Stage 1 Clutch Quote:
It sounds as if you are STILL working the kinks out of it as your last thread described. You did not need to make a new thread for this continuing problem that you are trying to fix. You could have rather simply updated your other thread as it is not even 4 days old yet...
I won't lock it this time but please take note of this for future posts... Have you checked your coil yet to make sure it hasn't gone bad? I've noticed that is usually a common problem with the 90 motors...
-Brian
Boost leak?
1991 GSX 2.3 Stroker |
Sorry about the double post... I forgot that I asked about this already...(I figured the tps would fix it and was more concerned with the tranny.) But anyways, I thought about boost/vac leak and was planning to build a pressure tester this weekend. What can I do to test the coil? And why would it make my car bog like that? Thanks again.
-Brian
So I should check the voltage at the end of the spark plug wires? Or at the coil itself, or does it matter? And am I just checking to see if they're the same or is there a specific number I'm looking for? Thanks again.
-Brian
Actually, I can't say that I do.
Ok, connect the one terminal to the middle post. Then connect the other to each of the outside posts and test each one. I can't remember right now what your resistance needs to be for it to be good still... Hopefully somebody else does and posts it up?
-Brian
Ignition Coil Resistance (Eclipse 2.0L)
Using a DVOM, measure primary coil resistance between ignition coil connector terminals No. 2 and No. 4 (coils for cylinders No. 1 and No. 4) and between terminals No. 4 and No. 1 (coils for cylinders No. 2 and No. 3). Measure secondary coil resistance between coil towers for cylinders No. 1 and No. 4 and between coil towers for cylinders No. 2 and No. 3. DIS IGNITION COIL RESISTANCE - Ohms @ 68°F (20°C) Primary Secondary .77-.95 10.3-13.9 |
Thank you Garrett.
-Brian
Okay guys, here's the update... when I was going to test the ignition coil resistance, I noticed something funny. I don't think that my spark plug wires are routed correctly (ie wrong coil to wrong plug). I have a 90 and I know they're different than later years, can anyone point me in the right direction, or possibly tell me how they should be routed? Thanks again.
I can't remember the order on the 90's... You should pick up a Haynes manual for it then you'll have all this info and more. I've found my book to be very helpful in several situations for both my cars.
-Brian
I have a Haynes manual, but it doesn't have that info in it, it's very ambiguous about the 90 model year.
