Old 10-20-2006, 12:11 PM
CamaroRScrazy CamaroRScrazy is offline
Brake fluid flush
I have a V6 3.8L. It has ABS and probably contraction control. Is there anything I need to know for a brake fluid flush in order not mess up the brake system?
Thanks.
Old 10-20-2006, 12:19 PM
wrightz28's Avatar
wrightz28 wrightz28 is offline
is bring'n sexy back
Re: Brake fluid flush
vacuum pump on the bleeder screws is the easiest way in my opinion. just have assistant on hand to keep the resivoir full.
Old 10-25-2006, 10:01 PM
CamarosRsweet94's Avatar
CamarosRsweet94 CamarosRsweet94 is offline
I am not familiar with the contraction control system installed on cars? Does it have something to do with getting your pregnant wife/girlfriend to the hospital without soiling the car's interior?
1994 3.4L Chevrolet Camaro - No more
2006 Hyundai Sonata
Old 10-26-2006, 08:31 AM
The manual says, "Do not attemp this procedure if your vehicle is equipped with the Traction Control System, as the brake system can not be bled withoug the use of a Tech or T-100 (CAMS) scan tool."
Actually I'm not sure if my 96 Camaro RS is equipped with Traction control system. It might, because I saw "low traction" light on the dashboard.
Old 10-26-2006, 08:56 AM
wrightz28's Avatar
If you have it, it will illuminate the "low trac' light during the system & bulb check @ startup.
Old 10-26-2006, 11:42 PM
blindeyed's Avatar
blindeyed blindeyed is offline
eBay aDdict™
Send a message via AIM to blindeyed
The V6's didnt come with traction control. Some did however come with a 2nd gear start button to help grab traction on wet surfaces. And Wright, I dont have T/C and my low trac light lights up on startup...
- Jason
1995 Pontiac Firebird
User Guidelines | VB Codes Explained | AF Merchandise
"Each of us, is in the scheme of things, insignificant.
But millions of insignificant people, doing a tiny bit,
can add up to be a very significant force."
Old 10-27-2006, 09:03 AM
wrightz28's Avatar
Removes foot from mouth looking dumfounded....
The General must be going loco?
Old 10-27-2006, 09:26 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Thanks.
Main thing to remember with ABS brakes is do not let it run dry on fluid.
keep that master cylinder filled up.
Depending on what ABS system you have some will require a ABS bleeder capable scanner to bleed them if the ABS ststem gets air in it.
MT
MT
