Old 10-20-2006, 11:25 AM
narcisis420 narcisis420 is offline
high flow catalytic converter..?
Hey guys,
I was looking to replace my catalytic converter (1995 Buick LeSabre 3.8L) and I was trying to find a high-flow one with a nice mirror finish, but I was having trouble finding one.
Any ideas? Magnaflow was my best bet I think.
Old 10-20-2006, 03:14 PM
Alibi's Avatar
Alibi Alibi is offline
Send a message via Yahoo to Alibi
Re: high flow catalytic converter..?
Mirror finish? why? It is just going to scuffed up from the road anyway...
Anyway, I've got a Magnaflow Hi-flow cat converter off ebay for about $60. 2.5 diameter, I think the newer pipes (newer than 89) are still 2.5 diameter.
-Eric
89 LeSabre T-Type: CAI, STB, F41 Suspension, Moog Ball joints and tie rods, dual-out flowmaster and dual tips, Pointiac CD HU, Delco type 2 Ignition, etc.
Basic H/C body info:http://www.3800power.bravehost.com/index.htm
http://www.cardomain.com/ride/2318168
Old 10-21-2006, 11:44 AM
Well they say the ones with a mirror finish is better for heat or somethin.. I don't really know to tell you the truth I just thought it looked cool.
Also, is 2.5 diameter like.. the "set number" for 95 Lesabre's? Because I was looking around at cats and got kinda confused, some have a 2.5 diameter, some a 3, then some said like 2 out 1 in or something like that. I assume the larger the diameter the better the air flow, am I restricted to a cat with a 2.5 diameter?
Old 10-22-2006, 09:34 AM
Alibi's Avatar
The diameter is the inlet and outlet pipe size. Unless you want to change the whole exhaust size, you are stuck with the stock size (2.5 is what my LeSabre is, I assume yours is the same but you ought to find out for sure).
If you can find a polished cat converter, then OK but I don't really know if any extra heat given off would be significant. Plus, whos going to be looking under the car other than you or a mechanic?
-Eric
Old 10-22-2006, 10:53 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Originally Posted by narcisis420
Hey guys,
Does it really need replaced?
You will be better of just replacing with stock OEM type.
If you want chrome hang some big pipes out the real or put it on the engine.
MT
MT
Old 10-22-2006, 11:52 AM
HotZ28's Avatar
HotZ28 HotZ28 is offline
AF Moderator Elite
If you really want a nice “shiny” cat, you can find them here. I personally use the Universal 8100 cats on my Z28. All of Random Tech cats are “high flow” and made from stainless steel, which is bright and shiny. These are far superior to OEM cats in every way, including price. Select the 1995 Buick LeSabre in the link above.
Old 10-23-2006, 03:49 PM
Ah.. thanks! I was going to go for the first one on the list, it says it's a
"Universal Random Technology Universal 9000 Series Hi-Flow Catalytic Converter #Universal 9000"
After I clicked it I was brought to a diameter selection page, the first selection says 2-1/2 and I think that's my car going off of earlier posts - so I'll grab that one. It has a selection for a kit.. is this required? I'll get the first one on that list, it should be the correct one I need going off of it's item coding.
I can't wait til I get this thing, my CIA is already on the way too! YES!
Thanks for the info!
