Go Back   Automotive Forums Car Chat > Ford > Explorer | Explorer Sport Trac
Old 10-20-2006, 08:37 AM
Teal95Jimmy's Avatar
Teal95Jimmy Teal95Jimmy is offline
Send a message via AIM to Teal95Jimmy
2000 Explorer with no spark
Hi, I have a 2000 explorer xlt 4x4 with the 4.0L SOHC V6 with about 95k miles on it. I have been losing fuel economy with a few sputters here and there when driving and now it won't start. Took one of the wires off the plug and put a screw driver in and cranked but did not get any spark. Ran the code reader and it did not come up with any faults. Any suggestions before i start throwing parts at it? I'm thinking the coil pack, good spot to start, how to test it?
Old 10-20-2006, 09:01 AM
Re: 2000 Explorer with no spark
add to the last post, when i crank the tach does not move off 0. dont know if it usually does or not when cranking, its my dads truck and just trying to make it work again
Old 10-20-2006, 02:27 PM
g1smith's Avatar
g1smith g1smith is offline
I had a similar problem with a Jeep Cheroke and replaced the Crank Position Sensor. If that doesn't do it for you, try the Cam Position Sensor. Problems with these two sensors should set an error code.
Old 10-21-2006, 12:02 PM
So problem solved. Bought a new coil pack, that wasn't it. So went and wiggled the wires to the pcm crank sensor and it fired up. Who would have thought
