car won't start...no spark!
Any ideas? I have a long list of things that it ISN'T including:
ignition module ignition coil alternator (although my new alt. isn't doing anything to help the batt.....) Fuses Fuse block voltage to distributor the wiring is a little questionable, but the pos. feed from the bat. to the starter to the alternator is fine...replaced in fact. Any help is gladly welcome thanks. - Nick |
Re: car won't start...no spark!
If it's an HEI, there could be a module or coil/reluctor assembly (the pickup coil, not the ignition coil) - PROVIDED that you have absolutely ruled out the ignition coil and power. HEI also uses a capacitor on the inside of the distributor that looks like a condensor (which itself is another name for capacitor) - check this per above and replace if it has low ohms (in the 0-10 ohm range). On a breaker points distributor, you should be getting 10-11 volts to the COIL + terminal, due to the ballast resistor - the wire itself is a ballast resistor on a GM. On an HEI, you should be getting full battery/alternator power to the BAT terminal - the HEI system does not use a ballast resistor.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1! 2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness! 1967 El Camino L79/M20 old school asphalt raper Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have. |
Have to agree with silicon212, the pints seem to be a weak area in the ignition system. My 71's pints went out around once a year till I got MSD. Its a pretty cheap fix, I would just raplace the points, condenser, and whil your at it the cap and rotar as well (if it looks like they need it)
The wiring to my coil was also not getting a good connection which gave me no spark. -zach |
